Raspberry Pi Forum How to break out of a while True: loop with a button
  • Replies 22 replies
  • Subscribers 703 subscribers
  • Views 12408 views
flypadre
flypadre over 10 years ago
I've been working on some python scripts accessing the gpio pins on my rpi to light an led and I ran into a little problem I'm not sure how to solve.
My code looks something like this minus some setup statements
def ledblink():
     while True:
          GPIO.output(13, True)
          time.sleep(.5)
          GPIO.output(13, False)
          time.sleep(.5)
def ledoff():
button = Button(root, text = 'LED ON', command = ledblink)
button.pack()
offbutton = Button(root, text = 'LED OFF', command = ledoff)
offbutton.pack()
As you can probably tell using tkinter for my gui. Also, as you can probably tell once I click the on button, that is all this program is going to let me do, the led blinks and continues because True is always True. How can I keep an indefinite loop running so that I can have a blinking led and still be able to break out of the loop when I want to turn things off? This was easy when I wanted to simply turn the led on and off, but not so easy with the loop I have to make it blink.
Just an FYI I was able to break out of the loop in my script version by using a try/except in which I used KeyboardInterrupt to call GPIO.cleanup() but I'm not sure how to do this in a gui.
  • rew
    0 rew over 10 years ago in reply to e14 Contributor
    Richard, you're my kind of man! I like your style! :-)
    I would write this functionality exactly as you did. If we were given this as an assignment at school, we'd be accused of cheating because all that's changed are the variable names.....
  • flypadre
    0 flypadre over 10 years ago in reply to e14 Contributor
    This is great too. Thanks for the code!
