Raspberry Pi Forum How to break out of a while True: loop with a button
  • Replies 22 replies
  • Subscribers 703 subscribers
  • Views 12402 views
flypadre
flypadre over 10 years ago
I've been working on some python scripts accessing the gpio pins on my rpi to light an led and I ran into a little problem I'm not sure how to solve.
My code looks something like this minus some setup statements
def ledblink():
     while True:
          GPIO.output(13, True)
          time.sleep(.5)
          GPIO.output(13, False)
          time.sleep(.5)
def ledoff():
button = Button(root, text = 'LED ON', command = ledblink)
button.pack()
offbutton = Button(root, text = 'LED OFF', command = ledoff)
offbutton.pack()
As you can probably tell using tkinter for my gui. Also, as you can probably tell once I click the on button, that is all this program is going to let me do, the led blinks and continues because True is always True. How can I keep an indefinite loop running so that I can have a blinking led and still be able to break out of the loop when I want to turn things off? This was easy when I wanted to simply turn the led on and off, but not so easy with the loop I have to make it blink.
Just an FYI I was able to break out of the loop in my script version by using a try/except in which I used KeyboardInterrupt to call GPIO.cleanup() but I'm not sure how to do this in a gui.
    0 e14 Contributor over 10 years ago in reply to flypadre
    Here's an entire working code that you can save and run, I have used a thread for ease of use and responsiveness as well as system efficiency. There are really only 4 extra lines of code to produce the threaded alternative, I also added a few extra bits here and there. Making global variables writeable within functions for simplicity. Any questions please just ask! I'm here to help rather than say what you should/shouldn't be doing, I'll always respond by providing tested functioning code
    import Tkinter as tk
    import time
    import threading
    switch = True
    root = tk.Tk()
    def blink():
     def run():
      while (switch == True):
       print('BLINK...BLINK...')
       time.sleep(0.5)
       if switch == False:
        break
     thread = threading.Thread(target=run)
     thread.start()
    def switchon():
     global switch
     switch = True
     print 'switch on'
     blink()
    def switchoff():
     print 'switch off'
     global switch
     switch = False
    def kill():
     root.destroy()
    onbutton = tk.Button(root, text = "Blink ON", command = switchon)
    onbutton.pack()
    offbutton =  tk.Button(root, text = "Blink OFF", command = switchoff)
    offbutton.pack()
    killbutton = tk.Button(root, text = "EXIT", command = kill)
    killbutton.pack()
    root.mainloop()
  • rew
    0 rew over 10 years ago in reply to e14 Contributor
    Great! That should work.
    One little suggestion: Move the "blink ()" call to the main at the bottom. Then you start the blink thread only once. As I read it (with my limited python knowledge), you will now start a new thread each time the "start blinking" button is pressed. So after turning it on and off again 5 times, there will be five threads  doing the blinking. This gives 5 times the output in the current incantation and a messy 5 blinking attempts through each other once you blink a real led....
    Furthermore, it would be neater to stop the thread in the kill function.
    Those are some valid points which would need attention in other languages, Python does much of the dirty work for us so there isn't any need to be concerned.
    The blink function needs to be called whenever the button is pressed which is why its in a function that the button press calls. Placing it at the bottom will start the blinking but once the stop button is pressed, the start button will never doing anything.
    Once the while loop breaks, the thread closes itself automatically through the Python subsystem and gets garbage collected.
    If the start button is pressed again once the thread is actually running then additional threads will build up, this could be easily solved if it becomes a problem which is unlikely in a single user scenario. If it was something that I was going to release with a product then that would certainly be something that needs addressing, for now I think the Original Posters question has been answered and I'm happy to help with any future queries.
  • rew
    Ooops. I was thinking of a mix of what you wrote and what I suggested. You're right! I mis-read what you coded. Sorry! Still, I'd prefer to have a "do the blinking" thread that is started once.
    Interesting discussion.
    Typically, I write a more simplified threaded procedure so that the straight-line code avoids embedded procedures (my preference or "style").  For whatever it is worth,
    # Changes to original code on 2016-10-21 15:21 USA CT
    # Simplified blink() procedure for future enhancement
    # Moved threading references to main code section
    # Doubled sleep time (not significant)
    # Renamed "switch" to "flag_blinking" (not significant)
    # Introduced flag_exiting
    import time
    import threading
    flag_blinking = False
    flag_exiting = False
    root = tk.Tk()
    def blink():
        global flag_blinking
        global flag_exiting
        while ( True ):
            if (flag_blinking == True):
            if (flag_exiting == True):
                return
            time.sleep(1.0)
    def switchon():
        flag_blinking = True
        print 'flag_blinking on'
    def switchoff():
        print 'flag_blinking off'
    def kill():
        global flag_exiting
        flag_exiting = True
        root.destroy()
    thread = threading.Thread(target=blink)
    thread.start()
    onbutton.pack()
    offbutton.pack()
    killbutton.pack()
    root.mainloop()
    Hey, another Toaru Majutsu fan? image
    Yes image
    ps. Its good to see somebody else's perspective followed up with a working example, shows how a persons coding is unique and individual to them as their fingerprints are!!
  • flypadre
    0 flypadre over 10 years ago in reply to e14 Contributor
    I tried to use the code that you supplied but I was unable to get it to work. Like before the interface locks up once the while loop was entered. image
  • flypadre
    I was launching it within IDLE.
  • flypadre
    That was great, I was looking at different threading examples online but never found anything as simple as what you just presented. Really appreciate the example!image
