Raspberry Pi Forum RPi 3 A/V out
  • Replies 13 replies
  • Answers 4 answers
  • Subscribers 707 subscribers
  • Views 11430 views
  • raspberry pi av out
  • av out
  • raspberry pi 3
RPi 3 A/V out
cloud12077
cloud12077 over 9 years ago
I'm new to the forums, but I have been reading through other posts and I can't seem to find the solution.
I'm trying to get A/V out working. HDMI works just fine, but this pi will be for my niece and her TV doesn't have any HDMI.
Based on the following diagram my camcorder cable will work using the right audio (red). I have even tested with my multimeter and verified my A/V cable does in fact follow the camcorder SRRT.
Diagram
While the HDMI is disconnected I have tried the following:
Hold 3 during boot up
Hold 4 during boot up
Tried each RCA plug as video during boot up (just in case)
Removed # from sdtv_mode=2 config.txt
Any thoughts?
  • COMPACT
    0 COMPACT over 9 years ago
    Be aware that the output quality and resolution will be greatly inferior.
  • COMPACT
    Have you checked the System File?
  • COMPACT
    0 COMPACT over 9 years ago in reply to COMPACT
    And did you press '3' to output to composite video when booting NOOBs for the first time?
  • COMPACT
    If you have an Oscilloscope use it to see if the video signal is present.
  • COMPACT
    Is the SD card bootable?
    0 dougw over 9 years ago
    RPi requires configuration to output composite video.
    I don't have an RPi3 to try this but it sounds like you are close:
    • if you press the 3 key repeatedly during boot it generates PAL
    • if you press the 4 key repeatedly during boot it generates NTSC
    Maybe it doesn't catch it every time, so you may need to do it a few times - I don't know if it is better to hold the key down or push it repeatedly.
    It should automatically boot to composite if the noob.config file is edited to include:
    display_mode=3
    or
    display_mode=4
  • cloud12077
    0 cloud12077 over 9 years ago in reply to COMPACT
    What should I be checking in the System File?
    Yes I've pressed 3 and pressed 4 during boot up.
    I don't have an Oscilloscope.
  • cloud12077
    0 cloud12077 over 9 years ago in reply to dougw
    I'll check this when I get to my office, since I left the Pi there over the weekend.
    I have an alternative, which is just using an HDMI to RCA converter, but would prefer not to confuse my niece with it.
  • COMPACT
    0 COMPACT over 9 years ago in reply to cloud12077
    You should seriously try to get one or a lend of one so you can view the electrical activity.
  • COMPACT
    The easiest way is to start with a fresh copy of NOOBS.
