Raspberry Pi Forum How to setup pi using putty on my laptop
  • Subscribers 705 subscribers
  • Views 1029 views
  • raspberry_pi_getting_started
prashusaraf
prashusaraf over 9 years ago
I am getting connection refused fatal error
  • clem57
    0 clem57 over 9 years ago
    Did you use raspi-config to turn SSH server on with the Pi? This is required since later versions of Jessie...
    Clem
    0 e14 Contributor over 9 years ago in reply to clem57
    I wish it hadn't been, its easier to disable it then it is to have to plug in a monitor, keyboard and mouse just to enable it. From a security point of view its understandable but I prefer to interact through ssh so its bad in my case as a user.
  • clem57
    0 clem57 over 9 years ago in reply to e14 Contributor
    A one time fix if you have no keyboard/mouse, take the SD card and connect to laptop. Under the /boot directory add a file named "ssh" with no data and no quotes. Then you can boot and get to the Raspberry Pi. But you must still do the prior comment and change the default password from raspberry to something else (otherwise you get a message asking you to do so).
    Clem
    Thanks! Im sure that will come in useful, it just seems silly to have to connect up all of those things if its not necessary.
