Raspberry Pi Forum h
  • Replies 11 replies
  • Answers 5 answers
  • Subscribers 709 subscribers
  • Views 1549 views
h
nschreiber0813
nschreiber0813 over 9 years ago
h
  • clem57
    0 clem57 over 9 years ago
    Start small with 2 or 3 and add later when needs and money dictate.
  • rachaelp
    0 rachaelp over 9 years ago
    Farnell do volume discounts if you buy a few:
    QuantityList Price
    1 - 2£33.96+VAT
    3 - 9£30.74+VAT
    10+£28.25+VAT
    So if you can afford 3-5 then you get a small discount, but you would need to buy a lot more to get a bigger discount.
    It's unlikely you'll get a large enough discount to enable you to buy 15 if you can only afford a maximum of 5 at the moment as they are already very well priced for what you get.
    As clem57 has already said, it might be best to start off with the 3-5 pi's you can afford to do, get the proof of concept working and then expand it to more when you can afford it.
    Please blog about your progress on here though, it might help get you some good ideas and vital feedback on what you are doing image
    Best Regards,
    Rachael
  • nschreiber0813
    0 nschreiber0813 over 9 years ago in reply to rachaelp
    Thank you very much. I knew that Newark did large quantity discounts on Pi's but I didn't know that Farnell had even better discounts. Thanks I will check it out. I also was going to test this on three raspberry pi's first before I did anything else. Thanks!!! That was very helpful.
  • nschreiber0813
    0 nschreiber0813 over 9 years ago in reply to clem57
    Thanks I will do that first. Thanks!!!
  • clem57
    0 clem57 over 9 years ago in reply to nschreiber0813
    Just an after thought, you may want to consider the Pi Zero. It only has one core, but they take less space. At $5 dollars apiece at Micro center, not a bad deal. Once catch, they only sell one at a time. You will also need to solve the lack of Ethernet and only micro USB connection. But that makes the project more fun solving the engineering problems.
  • rew
    0 rew over 9 years ago in reply to clem57
    You've got a funny idea there, clem! For "computing" there is not much "external" stuff you need except for a networking connection. So just plugging a cheap ethernet adapter into each pi zero should do the trick. Get yourself a TTL-serial adapter for configuration and debugging until the ethernet works....
  • nschreiber0813
    To be honest I would rather use a RPi3 than a pi zero for the sheer power. I appreciate the idea but I think I am already on the right route. Thanks though!!!
  • nschreiber0813
    0 nschreiber0813 over 9 years ago in reply to rew
    Yes I agree. That was precisely what I was going to do. Thanks!!!
  • Problemchild
    0 Problemchild over 9 years ago
    Noah, these tasks tend to be very parallel and can be  spread around different machines via the the network port efficiently.
    How ever the RPI is not compute centric... If you want lots of compute for your money go for a simple PC mobo. Almost any basic Mini ITX or whatever will have much more compute than a PI
    So if solving the problem is the requirement then doing it with RPIs isnt sensible for most configurations. If creating a cluster to learn from is the aim then go ahead.
  • nschreiber0813
    0 nschreiber0813 over 9 years ago in reply to Problemchild
    Okay thanks!!!
