Raspberry Pi Forum What is the "HUB" pinout for the Bitscope Blade Uno?
  • Subscribers 704 subscribers
  • Views 804 views
mike@goodey.org.uk
mike@goodey.org.uk over 9 years ago
And while we are at it, the documentation seems to imply that there is a processor reset facility on the board. Is there one, and if so where is it?
  • Workshopshed
    0 Workshopshed over 9 years ago
    Hi Mike, the hub connector is standard across the range, as per attached. The 4 pin connector allows you to pull the power and send signals on pin GP21. There's currently no software associated with this but you could use something like ipv1 'a software solution Adding a Shutdown Button to the Raspberry Pi B+ swapping the pin to 21.
