Raspberry Pi Forum Can't find the Jessie OS version of Raspbian
  • Answers 4 answers
  • Subscribers 706 subscribers
  • Views 3977 views
el14gsh
el14gsh over 9 years ago
I am attempting to download the Jessie OS version of Rasbian but I can not
find this version or even download it  through NOOBS since it is not one of the OSs
that NOOBS supports.  I was able to get the Jessie version about 1 week
ago but it seems it is no longer available.  Was it removed or am I not looking
at the right places ?
                    Jerry Hoffman@
  • bwelsby
    0 bwelsby over 9 years ago
    You can find the older versions here: https://downloads.raspberrypi.org/raspbian/images/
    Brian
    • Vote Up +6 Vote Down
  • el14gsh
    0 el14gsh over 9 years ago in reply to bwelsby
    Thank for the quick response.  I assume I just take the latest zip field with jessie in the name, unzip it and download in the Rasberry Pi.  Is that correct ?
    Sorry if the question sounds simplistic but I am a newbe to the Pi and would like not to make an obvious mistake.
    My other question, since I downloaded the latest NOOBS and it did NOT contain the Jessie OS can I assume that the site is no longer offering new versions
    Of Jessie or is there some other reason?
                   Jerry
  • el14gsh
                   Jerry
  • bwelsby
    0 bwelsby over 9 years ago in reply to el14gsh
    The last version of raspbian jessie is this one here  https://downloads.raspberrypi.org/raspbian/images/raspbian-2017-07-05/2017-07-05-raspbian-jessie.zip
    If you download this and unzip it you will get a single file 2017-07-05-raspbian-jessie.img. This is a binary SD card image and you need to write this to an SD card using the instructions
    here https://www.raspberrypi.org/documentation/installation/installing-images/README.md
    RASBIAN is based on the linux DEBIAN operating system customized for the raspberry pi, the latest is version 9 known as "stretch" the previous version 8 was known as "jessie".  I don't know if RPi people plan to continue support for raspbian jessie .
    The question is why do you need it and why won't the latest raspbian stretch do what you want?
    Brian
  • el14gsh
    Again thak you for the quick response and extremely usefull information.
    I am using an application called "Cayenne" that helps in the design of IOT circuits by freeing the user of the need to understand
    peripherals like sensor, motor etc.  The documentation for this app says that it is designed to run the Jessie OS on the Raspberry Pi.That is really the only reason I wanted that version.
                   Jerry Hoffman
  • bwelsby
    Ok I understand. The Cayenne software may work fine on the latest raspbian anyway but if not I am sure they will fix it so it does.
    Brian
