Raspberry Pi Forum Needing help
  • Answers 2 answers
  • Subscribers 705 subscribers
  • Views 593 views
Needing help
krebzy85
krebzy85 over 8 years ago
I am very new to this, and am not real techy.  I bout a Raspberry PI1 Modle B+ 512mb.  I have followed the instructions, and believe that i have the micro SD chi programmed right.  I have lugged it in and tried to get it to work and it will not power up.  the led lights are on, and everything id plugged in.  I have the TV the right channel, and have switched 3 different HDMI cables.  The TV still says no input.   Can anyone help me out......
thanks mike
  • beacon_dave
    0 beacon_dave over 8 years ago
    Take a closer look at the LEDs as they can tell you a bit more what is going on.
    If the R-Pi doesn't detect the display over HDMI it may be outputting the video on the composite RCA output instead - does your TV have a composite input to try ?
    Have you looked at these two resources: ?
    https://www.raspberrypi.org/forums/viewtopic.php?p=437084#p437084
    https://elinux.org/R-Pi_Troubleshooting
  • mgbarnaba
    0 mgbarnaba over 8 years ago
    Greetings,
    What do you have as a power source? It's been quite a spell since I tinkered with my RP but I remember you have to make sure there is enough current. If you think all is OK take it back to the vendor, as one of my 3 RP's was faulty right out of the pack plugged in place of another. Another thought, buy the loaded SD Card to get going faster. I recommend NOOBS https://www.raspberrypi.org/help/noobs-setup/2/
