Raspberry Pi Forum PI desktop: unable to reboot when booting from SSD
  • Subscribers 706 subscribers
  • Views 1691 views
  • pi desktop
termoen
termoen over 8 years ago
My Pi desktop is unable to reboot. The power is always turned off during the reboot process. Shutdown and Reboot give the same result. The blue power LED ring is flashing during the reboot. The process continues until the rainbow screen is shown before the power is cut. My PI desktop is booting from a SSD, and doesn't have a SD-card mounted. I've read that booting from anything but the SD-card results in an extra delay in the booting process. May this cause the problem? If so is there a solution to the problem? I have also tried a more powerful USB power supply with the same result.
I have the following components:
Elements 14 Raspberry Pi Desktop Case with On/Off Button, mSATA, RTC
Pi 3 Model B revision a02082, Linux raspberrypi 4.9.80-v7+, not using a SD-card
SAMSUNG SSD 850 EVO 500GB
USB power supply 5V 1.8A
  • dagv
    0 dagv over 8 years ago
    Hi.
    Probably your power supply is unefficient.
    I recently set up a pi desktop with a 2.0 A power supply and a 120GB mSSD, and got
    complaints about unsufficient power. You should at least get a 2.5, maybe a 3.0 A
    power supply.
    At least try this before anything else.
    Dag
  • mp2100
    0 mp2100 over 8 years ago
    I agree with  Dag.  Are there any messages on your screen after the rainbow screen?
    I looked around for specifications on that SSD.  From newegg.com:
           https://www.newegg.com/Product/Product.aspx?Item=N82E16820147373
    This states the power usage of the SSD as:
         Power Consumption (Idle) 50mW
         Power Consumption (Active) 3.0W
    With a 5 VDC power supply, 3.0 watts will draw 0.6 amps.
    From here:
         https://www.raspberrypi.org/magpi/raspberry-pi-3-specs-benchmarks/
    It rates the Pi 3 under CPU load at about 0.6 amps.
    You have only 1.8 amps total to work with so if there's anything else drawing power (keyboard, mouse) you can run out of power.
  • jomoenginer
    0 jomoenginer over 8 years ago
    The User guide suggests at least a 2.5A power supply if using a Pi 3, but I would go up to a 3A if you are using an SSD to boot from.
    https://www.element14.com/community/docs/DOC-87690/l/pi-desktop-user-manualenrev40pdf
