Raspberry Pi Forum Pidesktop headless
  • Subscribers 706 subscribers
  • Views 789 views
  • raspberry_pi_space
Pidesktop headless
dagv
dagv over 8 years ago
I tried to set up the PiDesktop headless, but did not succed.
Here's what I tried:
Had a running mSD card, and logged inn via ssh.
Cloned the mSD card to SSD with dd. The cloning
went well.
Changed the /boot/cmdline.txt to boot from sda2.
Bot no boot.
What procedures exist to set up in CLI?
Dag
  • malakai
    0 malakai over 8 years ago
    You should be able to edit the file again on PC / MAC remove that line. To get it back to where it worked. Not sure which version of Pi or OS you are using.
    I believe the newer Jessie Builds have broken /boot/cmdline.txt to boot from sda2
    https://www.raspberrypi.org/forums/viewtopic.php?t=180716
    Here are some tutorials to help boot from SSD
    https://www.raspberrypi.org/forums/viewtopic.php?t=205374
    https://www.makeuseof.com/tag/make-raspberry-pi-3-boot-usb/
  • dagv
    0 dagv over 8 years ago in reply to malakai
    Tank you for the answer.
    I was using the latest Raspbian Lite which is based on Stretch.
    I was able to edit the cmdline.txt to get back, but still I have not solved my problem.
    I was following the instructions for installing the PiDesktop with mSSD and setup a
    boot to the SSD. But since Raspbian Lite is a headless install, the ppp-hdclone cannot
    be used. I used ssh to log into th Pi.
    Thus I tried to copy on the CLI with dd. But the proper setup (config) I did not find
    a proper way of doing.
  • malakai
    0 malakai over 8 years ago in reply to dagv
    Is this any help?
    https://www.zdnet.com/article/raspberry-pi-adding-an-ssd-drive-to-the-pi-desktop-kit/
  • dagv
    Yes, thank you.
    I settled with (not the best) solution to keep the SD card and only added the SSD.
    I formatted the SSD and now mount it as /home, thus having about 120GB for the
    home directory.
    It will do for the time being, and the PiDesktop is running as a headless server on Raspbian Lite,
    which was what I aimed for.
