Raspberry Pi Forum RPi Official 7 Inch Touchscreen Not Working
  • Subscribers 704 subscribers
  • Views 5545 views
  • rasberry_pi_3_b_plus
s91arvindh
s91arvindh over 8 years ago
recently bought RPi 7 inch touchscreen and for few days it worked as expected, but When i tried to connect the touch screen with RPi, It displays with few color lines and nothing more . I have attached the reference picture for the same . Any help regarding this will be highly appreciated and please let me know if the required information is not sufficient ,
    0 shabaz over 8 years ago
    Hi Arvindh,
    There is a page here, see the comments at the bottom, there are perhaps several hundred comments there with symptoms and solutions:
    Raspberry Pi 7” Touchscreen Display
    Also, there are some photos here showing how you can examine the connectors to ensure they are correctly contacting with the flat flex:
    Raspberry Pi 7” Capacitive Touch Display: Assembly and Enclosure
    If this doesn't help, it could just be faulty and need replacing. But you should check those two links, because if it originally worked but now generates garbage, you've likely unseated a flat flex cable slightly.
