Raspberry Pi Forum Digital input & Relay output card for Raspberry Pi 3 Model B
  • Replies 7 replies
  • Answers 4 answers
  • Subscribers 709 subscribers
  • Views 1425 views
  • rasberry_pi_3_b_plus
jirafeprasanna
jirafeprasanna over 8 years ago
Hi
I am looking for Digital input & Relay output card for Raspberry Pi 3 Model B.
so help me which card will be compatible for this application.
by this card I want to interface Push Button input to Raspberry Pi & want to switch ON relay for further control.
for more detail you can refer attach file.
Prasanna Jirafe
9922135365
imageRP.docx
  • rew
    0 rew over 8 years ago
    I designed a card with relays that fits on your raspberry pi: Raspberry Relay
    It has a few breakout connectors intended for SPI and UART, but those can be used for buttons if you want (and don't need the SPI or UART).
  • jirafeprasanna
    0 jirafeprasanna over 8 years ago in reply to rew
    I am in  India , how can I get this or suggest the card which can be available in India.
  • rew
    0 rew over 8 years ago in reply to jirafeprasanna
    Click "add to cart", follow the directions and I'll ship it to you in India.... :-)
  • rachaelp
    0 rachaelp over 8 years ago in reply to jirafeprasanna
    On the page the Roger linked to if you scroll down to the bottom you will see a link to a page called Do you ship to ...?  if you read that page it states they ship worldwide so I would expect you would be able to get that card shipped to India.
    Best Regards,
    Rachael
  • rachaelp
    0 rachaelp over 8 years ago in reply to rew
    You beat me to it image
  • Sean_Miller
    0 Sean_Miller over 8 years ago
    You can make this.  You need a tactile switch, 10K pull-up resistor, an NPN transistor, 1K resistor between the Pi output and transistor gate, and a relay.  You can google the schematic.
    0 mcb1 over 8 years ago in reply to Sean_Miller
    Even better use the opto-coupled relays and you might need to reduce the series resistor
    RELAYS and POWER CONTROL
    Read the note about reducing the series resistor when driving from the Raspberry Pi.
    NOTE: It is sometimes possible to use these relay boards with 3.3V signals, IF the JD-VCC(RelayPower) is provided from a +5V supply and the VCC to JD-VCC jumper is removed. . That 5V relay supply could be totally isolated from the 3.3V device, or have a common ground IF opto-isolation is not needed.  If used with isolated 3.3V signals, VCC (To the input of the opto-isolator, next to the IN pins) should be connected to the 3.3V device's +3.3V supply. NOTE: Some RaspberryPi users have found that some relays are reliable and others do not actuate sometimes. It may be necessary to change the value of R1 from 1000 ohms to something like 220 ohms, or supply +5V to the VCC connection.
