Raspberry Pi Forum Toi 3b+ and enocean pi
  • Answers 3 answers
  • Subscribers 705 subscribers
  • Views 940 views
  • rasberry_pi_3_b_plus
lorenzo2a
lorenzo2a over 7 years ago
Hi everybody.
Can you help me, I’ve bought a raspberry 3 B+ and an enocean pi but there no way for me to make a good configuration.
The only links I’ve found to explain me are 5years old so don’t work with Rpi3b+.
Can you help me please because I really don’t know what I can do....
thanks a lot
laurent
  • inghernandez
    0 inghernandez over 7 years ago
    Laurent:
    inthe following link https://www.raspberrypi.org/ you can
    fin many information really helpfull.
    it´s a good way to start with.
    Regards
  • Gough Lui
    0 Gough Lui over 7 years ago
    You will need to provide us more information - e.g.
    - What guide are you following?
    - How have you connected the board to the Pi?
    - Why doesn't it work - what error messages are you seeing?
    - What operating system are you running on your Raspberry Pi?
    - What have you tried to get it working?
    - Do you have other Enocean system devices (switches, sensors, etc) that you're trying to integrate with it?
    - Gough
  • mp2100
    0 mp2100 over 7 years ago
    Laurent,
    Are you trying to use these instructions from element14:
    https://www.element14.com/community/docs/DOC-69363#downloads
    As you say, these are from 2013.  A lot has changed in 5+ years.  Reading through the instructions, it seems to be mostly good guidance.  One step in the instructions that has me concerned is the “USB 300” firmware installation from github.
    https://github.com/Hexxeh/rpi-update
    It looks to be updated in December 2018 but the raspberry Pi 3B+ has a lot of changes from previous models.  Have you asked “Hexxeh” if this is compatible with the 3B+?
  • Gough Lui
    0 Gough Lui over 7 years ago in reply to mp2100
    As far as I know, rpi-update was a mechanism for easier updating for Raspberry Pi kernels from the early days. It wasn't long before the kernel updates were rolled into the regular package management system, so a sudo apt-get install dist-upgrade was all that was needed to update the kernel, so using this fell by the wayside.
    From what I can see, rpi-update will NOT be required, as the device itself seems to make use of an FTDI USB to Serial converter chip on-board. The FT232R has out-of-box support since Debian Wheezy (2016). I suspect the steps above were required for older Debian Jessie (2015) or older based installations.
    - Gough
