Raspberry Pi Forum element 7 inch raspberry pi 3 b+
  • Subscribers 704 subscribers
  • Views 1034 views
nopian61
nopian61 over 6 years ago
hi ı have element 14 7 inch screen it is not working how ı can test it could you share datasheet or service manuel  or how ı can buy adaptorboard ı think broken adaptor board
  • clem57
    0 clem57 over 6 years ago
    Do you have a digital meter to test voltage and ground?
  • nopian61
    0 nopian61 over 6 years ago in reply to clem57
    yesı have ı controlled board but ı dont understant  datasheet should me
    0 shabaz over 6 years ago
    Hi Omer,
    There are no spares or service manual, and there is no engineering-level datasheet either. It is a consumer product, these documents have never been available.
    If you are 100% sure your board is damaged, if you're lucky maybe eventually someone sells (say) a broken screen display on ebay, and you can swap out the board.
    If you are not sure, then you can do a manual visible inspection (without a service manual) in case you have connected it incorrectly, and check if the supply is capable of operating the display and the Pi. Connections, and power supply are popular issues. Anyway, you can refer here for some detailed photos showing the connections, that you can compare with your set-up: Raspberry Pi 7” Capacitive Touch Display: Assembly and Enclosure
    For even more troubleshooting, there are hundreds of comments here, covering many topics, so it is worth you scanning through the comments, in case you can identify a similar situation and it's resolution:
    Raspberry Pi 7” Touchscreen Display
