Raspberry Pi Forum Python help with GPIO
  • Replies 27 replies
  • Answers 10 answers
  • Subscribers 705 subscribers
  • Views 5264 views
rcayot
rcayot over 6 years ago
Okay, I guess it is time to ask for help.  I have learned how to breadboard up a set of traffic lights, a button and a buzzer.  I can get them all to work with simple python programs.  Now I want to interrupt the normal light sequence when the button is pushed.  I can even get a detect event to work.  What I do not seem to be able to do is condition the "if" or "while" loop for the lights on the event.
I have a callback and it seems to work, so I can print the status of the "button is pressed" but I cannot pass it as "true" to the loop.  I suspect it may be that when defining "btnpushed" it is local to only the callback loop?
i can self learn, but most of the tutorials I see are very single topic context, like what is a while loop or what is an if loop.  Any pointers to a good example of using these functions would be great!
i hope this is clear.
Roger Ayotte
    0 shabaz over 6 years ago in reply to rcayot
    rcayot  wrote:
    I happened to be trying that, it works when only = instead of ==
    I added a print statement after btnpushed = 0 and at the start of the program it prints 0, and when I press the button, it prints 1 but on every case the lights keep cycling.
    Roger
    That's because every variable you're modifying in that def block is _local_. You need to define it as global.
  • rcayot
    0 rcayot over 6 years ago in reply to shabaz
    yes? using btnpushed as global worked as far as getting the loop interrupted?
    Now back to work on the rest of it!
    Thanks all who helped!
    Roger Ayotte
    0 genebren over 6 years ago in reply to rcayot
    Roger,
    I would assume that you will also need an GPIO.add_event_detect(26, GPIO.FALLING, callback=cb1, bouncetime=300) statement to detect GPIO.RISING to clear btnpushed in order to get your loop running again.
  • clem57
    0 clem57 over 6 years ago in reply to shabaz
    Bingo shabaz. Because line 13 sets btnpushed = 0, it is global in scope. But inside cb1, line 17 does a comparison and not an assign on global btnpushed. I guess the value is never changed as a result.
    yes, when I set btnpushed to 1, the while btnpushed == 0 does not run.
    when set to 0 it runs, and when I get an event that sets it to 1 the while btnpushed = 0 still runs!
    Roger
    Kindly see https://www.guru99.com/python-operators-complete-tutorial.html where much of this is explained.
    Various comparison operators are ( ==, != , <>, >,<=, etc) image Notice all are 2 symbols not one.
    Various assignment operators used in Python are (+=, - = , *=, /= , etc.) image These are special compound assignments where the left side is operated(+-*/) on by the right creating a value to replace the left side.
    I hope this clears the air so to speak.
    If not, let me know...
    Clem
  • clem57
    Please read my post before...
  • rcayot
    0 rcayot over 6 years ago in reply to genebren
    Thanks, I was wondering how I was going to do that!
    roger
  • yoyojacky
    0 yoyojacky over 6 years ago
    Try this:
    1. import RPi.GPIO as GPIO
    2. from time import sleep
    3. from signal import pause
    4. GPIO.setmode(GPIO.BCM)
    5. GPIO.setup(25, GPIO.OUT, initial=GPIO.LOW)  # red LED
    6. GPIO.setup(12, GPIO.OUT, initial=GPIO.LOW)  # yellow LED
    7. GPIO.setup(20, GPIO.OUT, initial=GPIO.LOW)  # green LED
    8. btnpushed = 0
    9. GPIO.setup(26, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                           def  blinking():
    1.        GPIO.output(20, GPIO.HIGH)  # green on
    2.         sleep(5)  #
    3.         GPIO.output(20, GPIO.LOW)  # green off
    4.         sleep(0.01)
    5.         GPIO.output(12, GPIO.HIGH)  # yellow on
    6.         sleep(2)
    7.         GPIO.output(12, GPIO.LOW)  # yellow off
    8.         GPIO.output(25, GPIO.HIGH)  # red on
    9.         sleep(5)
    10.         GPIO.output(25, GPIO.LOW)  # red off
                         def  noblinking():
    1.        GPIO.output(20, GPIO.LOW)  # green off
    1.        GPIO.output(12, GPIO.LOW)  # yellow off
    1.        GPIO.output(25, GPIO.LOW)  # red off
    1. try:
    2.     while True:
                                    if  btnpushed == 0:
                                        blinking()
                                        print(btnpushed)
                                    else:
                                        noblinking()
                                        print(btnpushed)
    1. except KeyboardInterrupt:
    2.     GPIO.cleanup((25, 26, 12, 20))
    3. GPIO.cleanup((25, 26, 12, 20))
