Raspberry Pi Forum Wireless mouse stops working with disk on USB 3
  • Replies 7 replies
  • Subscribers 704 subscribers
  • Views 1822 views
  • raspberry pi 4 8gb
  • usb 3.0
  • wireless mouse
dr13
dr13 over 5 years ago
Wireless mouse stops working after connecting ssd disk on USB 3 on RASPI 4 B.
When the USB 2 is used the wireless mouse works.
    0 Jan Cumps over 5 years ago
    This may be related to the amount of power that's available for the USB devices and how much the SSD asks when in a type3 port.
    0 shabaz over 5 years ago
    Also electromagnetic interference can be a factor, I've seen WiFi drop out when using a USB-connected SSD with the Pi. It might just be marginal on USB 2. If that's the case, you can try different cables just in case they make a difference, perhaps try a ferrite or two around the cable, or re-routing wires slightly, or a different mouse or SSD. I don't knowit it will work or not though, these are just experimental things and it might not solve your problem. Short-term, if there's no issue on USB 2, you can continue to use that perhaps - it might not be much of a bottleneck if it is being used for some storage possibly.
  • parasquid
    0 parasquid over 5 years ago
    I am guessing your wireless mouse operates on the 2.4ghz band.
    There's some research showing evidence of interference between USB3.0 and devices operating on 2.4ghz https://www.intel.com/content/www/us/en/products/docs/io/universal-serial-bus/usb3-frequency-interference-paper.html
    The whitepaper recommends shielding the noisy USB3.0 device, among other things:
    Mitigation Methods
    Shielding the USB 3 .0* Peripheral Device
    As previously described in Section 3.1, noise due to the USB 3.0 data spectrum can radiate from a USB 3.0 peripheral device and its connector. Properly shielding the USB 3.0 peripheral device can help reduce the amount of noise emitted in the 2.4 GHz band. To illustrate this point, different areas of an external HDD were shielded, and for each case, noise emitted into the 2.4 GHz band was measured.
    Or, as you have shown, you can just use the USB2.0 slots for the wireless mouse (it doesn't take so much bandwidth so that should be fine).
    • Vote Up +5 Vote Down
  • dr13
    0 dr13 over 5 years ago in reply to Jan Cumps
    Thanks a lot
    So nothing much to do. Who wants to use cable mouse. so slower communication from the ssd on usb 2.
    David
  • dr13
    0 dr13 over 5 years ago in reply to shabaz
    Thanks man,
    Did anyone out there found a VM running on ARM.
    David
  • dr13
    0 dr13 over 5 years ago in reply to parasquid
    Thanks man,
    David
    0 shabaz over 5 years ago in reply to dr13
    (Duplicate of:
    VM for ARM cpu
