Raspberry Pi Forum Problems with Wifi/Ethernet connection
  • Subscribers 705 subscribers
  • Views 435 views
  • raspberry
  • wifi
  • ethernet
  • troubles
  • raspberrypi
I'm new in this world. I'm trying to set up the wifi but it's impossible! I have a wifi usb ( i dont know the name exacly). I tried to scan ( as it says in the screen) but it doesn't find any network. Then I tried to do it with Ethernet port, but maybe because I don't really know how it works, it doesn't catch the internet. So, I'll be very greatful if someone helps me.
Thank you
PS: I followed lots of tutorials step by step and I dont find the solution.
  • saturnv
    saturnv over 11 years ago
    Follow this link and you should be good to go
    http://www.howtogeek.com/167425/how-to-setup-wi-fi-on-your-raspberry-pi-via-the-command-line/
  • saturnv
    Your main directories are the /etc and the, /wpa-supplicant directories. also on the url  http://www.howtogeek.com/167425/how-to-setup-wi-fi-on-your-raspberry-pi-via-the-command-line/ start about half way down where it starts to talk about the wifi dongle.
    I've set up over a dozen pi wife's uses the EDIMAX dongle nd others with great success. Don't forget to reboot where told to do so.
  • saturnv
    saturnv over 11 years ago in reply to saturnv
    You will also want to add the line "auto wlan0" above the "allow-hotplug wlan0" line in the code. That way when you power up, the wlan0 will search for your wifi network according to the SSID and PASSWORD you entered in the scripting further down in the web page.
