Raspberry Pi Forum Disable camera LED
  • Subscribers 707 subscribers
  • Views 1265 views
  • led
  • leds
  • camera
Disable camera LED
dhaggar
dhaggar over 12 years ago
Is there any way to disable the LED on the pi camera board?
    To disable the red LED you simply need to add the following line to your config.txt file :
    disable_camera_led=1
  • dhaggar
    0 dhaggar over 12 years ago in reply to e14 Contributor
    What about the on-board leds? power, activity, network. Is there a control for these?
    0 e14 Contributor over 12 years ago in reply to dhaggar
    Do a google search, that's how I find out this information.
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to dhaggar
    Take a look at the RasPi schematics.  The power LED is hard-wired to 3.3V, so the only way to turn it off is to remove it or its current-limiting resistor.  Activity is controlled by the BCM2835 SoC, probably in the SD card driver.  You might be able to override it by changing the GPIO that drives the Activity LED from an output to an input.  The network LEDs are controlled by the LAN9512.  You can in principle control them by modifying the LAN9512 driver -- have fun with that.  It may be that someone has already done it and posted the results.
  • dhaggar
    0 dhaggar over 12 years ago in reply to johnbeetem
    That makes a non transparent case look like a good solution. image
    Thanks to all for the advice.
