Raspberry Pi Forum pi won't boot with gertduino
  • Subscribers 705 subscribers
  • Views 870 views
I have installed arduino ide on denbian pi  and followed the drogon.net instructions but I still get a sh can't access tty on power up and the whole thing stops there.
any ideas ?
    Hi Richard,
    Your not the only one having this issue, I have had the same but unfortunately not had time to look into it. I'll keep you updated if I find anything out.
    I started with noobs   and have now done all the updates and upgrades , still won't boot when gertduino attached . fyi  if that helps
  • johnbeetem
    0 johnbeetem over 12 years ago
    One possibility is that your power supply and/or micro USB cable can't handle the additional load you get with Gertduino attached.  I don't know how much current Gertduino uses.  Here's the RasPi Troubleshooting Wiki scrolled to the part about debugging power problems.
    0 e14 Contributor over 12 years ago in reply to johnbeetem
    the actual error is
    sh : can't access tty : job control turned off
    its unlikely to be a power issue , the same setup  runs fine with a chipkit_pi on board.
    fixed
    Atmega48 reset pin  (re) and she boots.  I uploaded blink to the gertduino  successfully and the rpi will now boot  without the atAtmega48 reset
    see
    Raspberry Pi • View topic - raspberry pi doesn't boot [solved (sort off)]
    Excellent find Richard glad you got it sorted! image
