Raspberry Pi Forum GPIO pins
  • Replies 12 replies
  • Subscribers 709 subscribers
  • Views 2708 views
  • wolfson
  • raspberry
  • pins
  • pi
  • gpio
  • audio_card
  • raspeberry_pi_accessories
GPIO pins
I wanted to use this for a HiFi project, but it seems to use all the GPIO pins, and I need more pins for IR reciever and a small LCD screen, is this impossible or is there a way around it?
    0 e14 Contributor over 12 years ago in reply to tonyhansen
    i2c is multi-drop, so you can connect that to your circuit in parallel to the WAC, if you can solder to the GPIO, and your device addresses don;t conflict with those used on the WAC.
    There are two GPIO brought to the header on the WAC. Those are the Pis default serial console UART Rx & Tx. You can disable the default serial console and use those pins as general IO (I think) so you may be OK.
    I have Tx and Rx blinking LEDs at me as I write this, just disabled the serial console and used them as normal.
    Time to do some more reading about I2C...
