Raspberry Pi Forum Raspberry pi camera issue
  • Replies 29 replies
  • Subscribers 705 subscribers
  • Views 6262 views
  • raspberrypi
When I try to read the camera I got the following debug error on the screen  "received unexpected camera control callback event 0x4f525245", can anybody help how to resolve this issue. or is this raspberry pi board has problem.
    0 e14 Contributor over 11 years ago in reply to clem57
    yep - re-seated it on this one and many of the others...
    the paste added the "1"'s...
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Please would you open a brand new question just for you. We kind of bootlegged someone else and not polite. Over there I will carefully post code and dialogue.
    Clem
    Yeah, Clem - as I mentioned before:
    Cables were swapped out.
    I tested the bad camera, you have the error message that I photographed (you can read it but it's blurry, and I pasted the text in this chain). "mmal: Received unexpected camera control callback event, 0x4f525245"
    I reseated the cable, have replaced the cable on many of the suspect ones, and mentioned that I reseated the camera module connector (see prior post).
    I have now reseated the bad camera after proving that a known good camera works (again see images). The suspect camera again fails with the same error I provided earlier.
    Please not that this is not solely *my* issue - there are many others with this same error... just google: mmal: Received unexpected camera control callback event, 0x4f525245"
    I will check on the FW state, though the problem does not follow the firmware version. I can reproduce good functionality on boards of all kinds as I can reproduce the failure on the same hardware - again, the problem seems to follow the camera hardware...
  • clem57
    #!/usr/bin/env python
    importtime
    importRPi.GPIO as GPIO
    GPIO.setmode(GPIO.BCM)
    # Set GPIO for camera LED
    # Use 5 for Model A/B and 32 for Model B+
    CAMLED =5
    # Set GPIO to output
    GPIO.setup(CAMLED, GPIO.OUT, initial=False)
    # Five iterations with half a second
    # between on and off
    for i in range(5):
        GPIO.output(CAMLED,True)   # On
        time.sleep(0.5)
        GPIO.output(CAMLED,False)  # Off
        time.sleep(0.5)
    No - in both shots, the cameras connected to the Pi have the red light on.
    In the second shot, I have the bad camera in the pic, disconnected.
    In the first shot, the suspect pi light turns on until I cntrl+c out of the raspistill -o command...
    I am more than happy to mail you a few of the bad Pi's - I don't want them back... I just want to know what happened.
  • rew
    0 rew over 11 years ago in reply to e14 Contributor
    Eh.... bad PI? It was a bad camera, right?
    I'm game. :-)
    I was already secretly considering sending you a free raspberry pi camera extension kit from my shop, as well as an extra flatcable so that if that happens to be the problem you can repair one other camera with that.
    Deal?
    0 e14 Contributor over 11 years ago in reply to rew
    I got your hardware, and will use it if any more cameras go bad. I have shipped the bad cameras to Clem - I will let you know what he sees when he gets back to me. I will return your hardware when all this dust settles. Thanks so much for your help, Roger!
  • rew
    Charlie, please just test the camera extension with working hardware, and then let everybody know something like: "It works, but I've got no use for it". Or maybe you do find a use for it.... :-)  No need to return the hardware.
