Raspberry Pi Forum Raspberry Pi + GPIO + Electro Aimant
  • Subscribers 705 subscribers
  • Views 1889 views
  • raspberry
  • gpio
  • relais
  • raspberrypi
Bonjour,
Je suis novice en électricité et je voudrai pouvoir déclencher en electro aimant, avec mon raspberry pi. Mais je ne sait pas quels matériels utiliser.
Mon electro aimant fonctionne avec ceci :
12V -> 500mA
24V -> 250mA
Si quelqu'un pouvait m'aider, sa sera d'une grand aide.
    Peut-être utiliser une planche avec un relais, comme celui-ci?
    PIFACE DIGITAL - PIFACE - BOARD, I/O EXPANSION, RASPBERRY | Farnell UK
  • rew
    0 rew over 12 years ago
    I can read French but I can't write it. I hope you can read English....
    I suspect that your magnet can be bought in two variants. One that is 12V500mA, and one that is 24V, 250mA. It is unlikely that the one you have can do both. (if it does, it probably has 4 connections, not two).
    My suggestion is to use the 12V version. get a 12V powersupply,
    http://nl.farnell.com/powerpax/sw3526/ac-dc-power-supply-12v-1-25a-euro/dp/1971795
    or http://www.ebay.com/itm/DC-12V-1A-AC-100-240V-Converter-Adapter-Charger-Power-Supply-EU-Plug-HE-/360762799333?pt=Laptop_Adapters_Chargers&hash=item53ff2374e5
    Then you need something that can switch the 12V.
    Our 3fets boards will work for that. http://www.bitwizard.nl/catalog/product_info.php?products_id=84
    The 7fets boards will also work (and will save you a few euros): http://www.bitwizard.nl/catalog/product_info.php?products_id=77
    To connect the you'll need a rpi_serial http://www.bitwizard.nl/catalog/product_info.php?products_id=69
    and if you want a little cable.
    if you want, you can power the raspberry pi from the 12V with a DCDC converter: http://www.bitwizard.nl/catalog/product_info.php?products_id=99 or http://www.ebay.com/itm/DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-HS-/111185855215?pt=LH_DefaultDomain_0&hash=item19e33182ef
  • iagorubio
    0 iagorubio over 12 years ago
    Sorry for my ignorance but I can't speak French.
    From the little I understood, you want to drive an electromagnet with your raspberry.
    You need something to drive an inductive load like:
    - A relay (relais) Relais électromécanique — Wikipédia
    - A transistor http://fr.wikipedia.org/wiki/Transistor
    Relays circuit:
    Example pre-made relay circuit Cooking Hacks - Shop - Actuators - Relays - Buy Relay Module (Arduino Compatible)
    Transistor array circuit ULN2003:
    Example pre-made circuit http://imall.iteadstudio.com/im120723012.html
  • johnbeetem
    0 johnbeetem over 12 years ago
    Voici un circuit pour faire marcher un relais:
    http://img.photobucket.com/albums/v47/satiagraha/elec/RelayDriver.gif
    Reliez le point "+1.5V" à une des points GPIO de la Framboise.  La résistance R1 est trop petit: je préfère 1KΩ.  Le transistor est probablement trop faible.  Je préfère un transistor Darlington comme TIP120 ou ULN2003.  La diode est très importante.  On appel ça une diode "flyback" en anglais.  Elle protège le transistor.
    Avant de relier le circuit à la Framboise, essayez-le avec une résistance grande (peut-être 4.7KΩ) au +12V.  Les transistors sont beaucoup moins chers que les Framboises.
