Raspberry Pi Forum Raspberry pi - handheld game device(gameboy-ish)
  • Replies 10 replies
  • Answers 2 answers
  • Subscribers 692 subscribers
  • Views 1316 views
  • raspberry
  • portable
  • pi
  • gameboy
  • handheld
  • guide
Hello, everyone.
I have been trying to find a complete guide(as detailed as possible) on  how to  make a handheld gaming device which use retroPi, but no Luck so far.
I am new to raspberry pi, but I wanna make something fun/useful. Most of what I have found are people who planned to make one and never posted how it went.
So I would be greatful if someone knew about a dummy guide for this subject image
Greetings,
Joakim.
  • danielmcgraw
    0 danielmcgraw over 12 years ago
    Hi Joakim,
    I've no experience with retropi but I can help with the hardware side of this project. Firstly have a look at this on youtube:
    http://www.youtube.com/watch?v=dUZjzQuTNX4
    This is the ben heck show building a portable Raspberry Pi. Some of the hardware he uses for the case is a bit out of the reach of most people but there are ways around this.
    For the display, most people using car reversing camera monitors such as this one.
    http://www.amazon.co.uk/inch-Digital-Rear-Monitor-Square-Black/dp/B0056WJP1M
    These have a RCA (composite) input, tends to be the yellow one, which is simply connected to the composite output on the Raspberry Pi, either by a cable or you can desolder the socket and wire it in directly if you are tight for space. All these need as well is a power supply connected to the red socket. Centre pin +12V, shield 0V.
    For the buttons and stuff, most people take apart a USB device (such as a mouse or a gamepad) and move the buttons around so they are where you need them to be.
    If this and the youtube video don't answer your questions, let me know which bits you are having problems with and I will do my best to answer your questions.
    Dan McGraw
    M0WUT
    0 Former Member over 12 years ago in reply to danielmcgraw
    Thanks for respond image
    I don't actually have a usb controller, so could I buy buttons like these
    PKG15 Tactile Push Momentary SPST Off on Switch TMS S | eBay
    and use them? if so, how do I attach them to the pi and how do I make them do stuff when pressed?
    If this is extremely much work I could of course just buy a new controller to destroy.
    0 Former Member over 12 years ago in reply to Former Member
    I just saw that usb controllers cost like 10$ from china, so I guess I can just buy one from there image
    but still wonder how to use these buttons as alternative buttons to keyboard. You think you can explain it?
  • danielmcgraw
    0 danielmcgraw over 12 years ago in reply to Former Member
    Using the advice from here.
    http://lifehacker.com/how-to-turn-your-raspberry-pi-into-a-retro-game-console-498561192
    It tells you how to set up using a SNES controller.
    Basically, you get any old USB controller (preferably with analog sticks as I'd imagine you'll want them sonner or later), follow the instructions on this website, when it gets to Step 3, you enter which buttons you would like to use. If it asks to press a button you don't have, press any button but make a note of what control you entered this button as and then delete that line in the config file as detailed on this website. e.g. device says "Press for L2" and you don't have a button for that, press anything and then delete the line in the config file input_player1_l2_btn = "4" where 4 is the number of the button you pressed.
    If you don't like the layout/want to arrange the controller in a different way, use a multimeter to find out which two points on the switch are shorted when the switch is pressed, desolder the switch and connect wires from the two points to the corresponding points on the switch.
    Any problems let me know.
    Dan McGraw
    M0WUT
    Thanks.
    ok I'll buy this usb controller.
    http://www.dx.com/p/usb-gamepad-with-analog-sticks-and-vibration-3686#.UzsWhoeKBaQ
    - Joakim
    Ok. I now got the pi(model B), and I've ordered:
    If I fail with one, I have one in backup.
    http://www.ebay.com/itm/370881292793
    Retro SNES USB Wired Classic Controller Gamepad for Windows PC Color | eBay
    I bought this screen:
    3 5 inch TFT LCD Rearview Monitor Car Reverse Backup Camera NI5L | eBay
    But what should I use for power?
    I see Ben(in the Ben Heck Show) use 2 li-ion batteries. Could you recommend some batteries + whatever I need for charging?
    And I guess I also need the "switching power regulator" so that the pi gets 5V. recommend one?
    - Joakim
  • danielmcgraw
    I've managed to find Ben Heck's part list for this project:
    Raspberry Pi Portable by benheck - Thingiverse
    and the battery he uses.
    http://www.amazon.com/gp/product/B002Y2LJW0/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
    although there is one for the same price with a greater capacity
    Amazon.com: Tenergy Li-Ion 18650 7.4V 2600mAh Battery PCB module With 22AWG Bare Leads: Toys & Games
    This seems as good a suggestion as any, it's fairly small and has good capacity.
    Personally, I wouldn't trust myself to take it to pieces but that's up to you.
    There is also a proper charger for it:http://www.amazon.com/TLP-2000-Tenergy-Universal-Charger-3-7V-14-8V/dp/B001BEXDRQ/ref=pd_bxgy_t_text_y
    and I'm afraid I'm not able to advise anything differently. Batteries are not my strong point, perhaps someone with more knowledge in this field can advise you better.
    As for the switching regulator, the cheapest thing I've found is to use a car cigarette lighter to USB adapter rated at the current you will need. MAKE SURE YOU LOOK AT THE CURRENT RATING, the unspecified ones are often 500mA and the Raspberry Pi draws at least 700mA (plus some for the screen and joystick) and this will ruin your regulator if you draw too much current(and quite possibly your raspberry pi.
    I would power the screen straight off the battery and the Raspberry Pi through the regulator.
    Hope this helps
    Dan McGraw
    M0WUT
    Thank you for good information image
    I see that he uses a teensy board to connect the wires from the buttons. You know if there are some cheaper alternatives?
    EDIT:
    Or is it possible to connect the buttons directly to the raspberry pi?
  • danielmcgraw
    Ok, two points.
    Point 1: Ben Heck uses the proper charger I recommended (shown at the start of the video) so I would use that.
    Point 2: Ben used the Teensy as a replacement for the controller as he broke it. If you treat your controller carefully (perhaps with less mutilation of the PCB) then yours should work fine. Just find the two points each switch connects using a multimeter and wire your switches to short these two points when pressed.
    Dan McGraw
    M0WUT
    This guide might help with controls.
    https://learn.adafruit.com/retro-gaming-with-raspberry-pi/buttons
    Alternative (much better quality) screens:
    Raspberry Pi • View topic - 2.8" TFT + Touch Shield Board v1b/c
    PiTFT Mini Kit - 320x240 2.8 TFT+Touchscreen for Raspberry Pi ID: 1601 - $34.95 : Adafruit Industries, Unique & fun DIY …
    fbcp to copy main display to tft
    https://github.com/tasanakorn/rpi-fbcp
