Raspberry Pi Forum Stripped version of Raspberry Pi
  • Replies 14 replies
  • Subscribers 679 subscribers
  • Views 2201 views
  • pi
  • rasberry
  • version
  • model
  • stripped
  • a
  Is there a possibility to buy a stripped version of the Pi model A? I need only the board with the processing power on it, 1 usb port, the power connector and the GPIO. So I could spare the audio jack, s-video, hdmi connector, camera connector, etc. If so, how much does it cost and where can I get it?
Razvan
  • Problemchild
    0 Problemchild over 11 years ago
    Razvan, such a thing does not exist if you want one you need to start with a stock model A then remove the connectors you do not want.
    If you cant do this then I'm sure there are plenty who will remove the connectors for you but his takes time and effort and probably cost you more than the RPI.
    Where are you any way? ...you'll need some one in your area to do this!
    Jeeze that ugly s-video connector is always in the way...
  • mconners
    0 mconners over 11 years ago in reply to Former Member
    Hey, I'm using that image
  • jlcarender
    0 jlcarender over 11 years ago
    Razvan Where are you located. If you are in the U.S. you could send me two model A's I could remove the things you do not want on it for the other model A. just let me know.
    Thanks guys but actually I don't need someone to remove them for me, I asked because without all these compoenents the board should be cheaper. I need to buy a few so finding it already stripped to the actual processing core would be nice. I am in Europe, Germany.
    Best Regards,
    Razvan
  • Problemchild
    0 Problemchild over 11 years ago in reply to Former Member
    yes but since these are all inserted by machines no one is going to stop the line and fish a few model A's off the line Sans some connectors.
    So the only way to get what you want is start with a normal model A then remove what you don't want.
  • johnbeetem
    0 johnbeetem over 11 years ago
    This summer element14 will start shipping the RasPi Compute Module: Introducing the NEW Raspberry Pi Compute Module
    It's basically a Model A with no external connectors in an SODIMM form factor, and is intended for integration into products instead of being a stand-alone "GNU/Linux Box" as the RasPi site used to say image
    However, at US$30 (quantity 100, according to http://linuxgizmos.com/raspberry-pi-morphs-into-30-dollar-com/), you're probably better off with a US$25 Model A image
  • mconners
    0 mconners over 11 years ago in reply to johnbeetem
    I'm a little bothered by the new form factor. To make something the size and shape of an industry standard part, but not implement the interface seems like a bad idea. I have not read enough about it though to know if there will be anything useful coming out of the connector, such as high speed I/O so that if you ganged a few(or a bunch) of them together you could build a really powerful cluster for a fairly low price.
    Mike
  • Problemchild
    0 Problemchild over 11 years ago in reply to mconners
    So basically they seem to have moved from been an educational  charity to been a provider of industrial computers. I  was hoping they would correct the problems in the original PI before diversifying !
  • Problemchild
    0 Problemchild over 11 years ago in reply to johnbeetem
    The only problem here John is that they don't exist yet and when they do you'll need to buy the baseboard making it bigger than the original PI.
    Only if you are doing a volume would you find it practical to do your own mother board with Power etc. I hope they do some more interesting peripherals with this design  it may make it useful for certain projects.
