Raspberry Pi Forum SD Card Reader for Raspberry Pi - DYNAMODE - CR-31 not working on a Windows PC
  • Subscribers 678 subscribers
  • Views 800 views
  • raspberry
  • pi
  • reader
  • dynamode
  • sdhc
  • sd
hkafeman
hkafeman over 11 years ago
Can anyone help please?
We purchased a DYNAMODE - CR-31 SD Card reader to use with a Raspberry Pi as recommended on the Farnell Web Site.
But in a windows PC (Vista or Windows 7) an 8GB or 32Gb SD card with a Raspberry Pi image shows as "No Media".Using the ext2fsd Software also shows "No Media"!
On a Linux PC it worked okay!
A new 32GB SD card with nothing on it worked okay on a Windows PC - Presumably because it was formatted as FAT32.
We have even had a second Card readr sent free of charge because Farnell Technical Support thought our first one was faulty. But the second one has the same issue.
I think, as per this web page, it could be due to SDHC:
        http://www.raspberrypi.org/forums/viewtopic.php?t=60371
Can anyone help with how to use it for our 32GB (or 8GB) SD cards?
Thanks and Regards
Henry
  • kidiccurus
    0 kidiccurus over 11 years ago
    What are you trying to do with the reader? Could you prepare the files on windows and then use Linux to transfer it to the card.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    I believe if the card is already setup for Linux as it would be once an image is on it for the PI, windows will no longer recognise it and will possibly keep prompting you to format if or ignore it
    A SD card writer software should still be able to apply a new image to it though (For example "Win32 Disk imager" )
    Regards
    peter
  • hkafeman
    0 hkafeman over 11 years ago
    Thank you both for your replies.
    All I am trying to do is to create an exact copy of a working Raspberry Pi SD card (32GB) on a second 32GB SD card so that I can plug it into a second Raspberry Pi!
    Surely that is something that many people have managed to do?
    But I have tried with "Win32 Disk Imager", "Paragon ExtFS for Windows",  "Ext2Fsd" and "DiskInternals Linux Reader" and none of these recognise the SD card image.
    I have not even managed to be able to make a copy on a Linux PC (did not recognise image) or an Apple Macbook (saved as a DMG file, but "Win32 Disk Imager" did not manage to write this to a new SD card as an image that would boot the Raspberry Pi!!!!
    Thanks and Regards
    Henry Kafeman
  • rew
    0 rew over 11 years ago in reply to hkafeman
    On  A Linux machine (like a raspberry pi), you can just copy over all the files. Should be a lot quicker than to copy over the whole 32Gb. (in fact I did exactly that yesterday.... :-) )
    (For most of the commands here you'll need to be root, so prefix them all with "sudo" or do "sudo -s" once....)
    To get this to work you need to partition the target SD card. Use any tool you like. Google for partitioning tools if necessary. On the other hand, if you have a bare "raspbian" system (and not based on noobs), your partition table is just the first block of the sd card, so:
    dd if=/dev/mmcblk0 of=/dev/sda count=1 ; blockdev --rereadpt /dev/sda
    will do the trick of copying the partition table of your running SD card to the one attached in an SD card reader.
    Next, format the partitions:
    mkfs.vfat /dev/sda1
    mkfs.ext4 /dev/sda2
    Mount the partitions:
    mount /dev/sda2 /mnt
    mkdir /mnt/boot
    mount /dev/sda1 /mnt/boot
    and then copy over the files:
    apt-get isntall rsync
    rsync -avP --one-file-system / /mnt/
    rsync -avP --one-file-system /boot/ /mnt/boot/
    And that will leave you with a raspberry pi bootable  image on the SD card that is accessible as sda.
  • hkafeman
    0 hkafeman over 11 years ago in reply to rew
    Roger
    Thank you very much for your reply which is along the right lines. Sorry for not replying sooner, but I have been busy with another aspect of the project.
    I now urgently need to copy my SD card in the next couple of days.
    So, as I am not very familiar with Linux, could you please show me how to modify the commands to suit NOOBS, etc.?
    One SD card I want to copy was definitely created from NOOBS and shows the following details:
    sudo parted
    GNU Parted 2.3
    Using /dev/mmcblk0
    Welcome to GNU Parted! Type 'help' to view a list of commands.
    (parted) print all
    Model: SD 00000 (sd/mmc)
    Disk /dev/mmcblk0: 7861MB
    Sector size (logical/physical): 512B/512B
    Partition Table: msdos
    Number  Start   End     Size    Type      File system  Flags
    1      1049kB  1263MB  1262MB  primary   fat32        lba
    2      1267MB  7861MB  6594MB  extended
    5      1271MB  1330MB  58.7MB  logical   fat16        lba
    6      1334MB  7861MB  6527MB  logical   ext4
    (parted) quit
    df -h -a
    Filesystem      Size  Used Avail Use% Mounted on
    rootfs          6.0G  1.8G  3.9G  32% /
    /dev/root      6.0G  1.8G  3.9G  32% /
    devtmpfs     211M     0  211M   0% /dev
    tmpfs           44M  1.2M   43M   3% /run
    tmpfs          5.0M     0  5.0M   0% /run/lock
    proc               0     0     0    - /proc
    sysfs              0     0     0    - /sys
    tmpfs           88M     0   88M   0% /run/shm
    devpts             0     0     0    - /dev/pts
    /dev/mmcblk0p5   56M   19M   38M  33% /boot
    So it seems the actual /boot partition is /dev/mmcblk0p5.
    BUT what now do I need to modify your suggested commands to suit the information above?
    Thanks and regards
    Henry
