Raspberry Pi Forum 8 gb NOOBS card doesn't fit into tiny mico SD slot. How does this work?
  • Replies 11 replies
  • Subscribers 685 subscribers
  • Views 2124 views
  • raspberry_pi_getting_started
I bought the Raspberry PI B+ with the 8 GB NOOBS card but the slot is too small for the card.  I couldn't find a video for B+.  Any ideas?
    The larger SD size card acts as a case for the micro card. If you look at the opposite end to the gold contacts you will see a recessed clip where you can release the micro card and insert into the Pi
    Hth
    0 Former Member over 11 years ago in reply to Former Member
    Thank you so much!
  • kidiccurus
    0 kidiccurus over 11 years ago in reply to Former Member
    Make sure you keep the case, if you want to reprogrammed the card them a micro SD to regular SD adaptor will be very helpful.
    0 Former Member over 11 years ago in reply to kidiccurus
    Can I use a micro memory card(8 GB), and plug it it using USB card reader and create image in it for the OS?
  • johnbeetem
    0 johnbeetem over 11 years ago in reply to Former Member
    My understanding is that you can use a Micro SD card provided that you program it using a full-size SD adapter.  This is what I do with my RasPi Model B.
    I can't find a source to confirm this, but I read somewhere that by default Micro SD cards are formatted differently from full-size SD cards, but if you use an adapter the Micro SD card is formatted like a full-size SD card.  RasPi Model A/B expects to see a full-size SD card.  I don't know whether Model B+ expects its Micro SD card to have full-size formatting.
    If anyone can confirm this with links and/or refute this, please add comments.
    0 Former Member over 11 years ago in reply to johnbeetem
    Thanks John,
    I do have a model B+ indeed, and I think it should work. I'm still inchoate in Embedded domain and want to learn a lot about using this. By the way, can I use C/C++ to code in Pi or python is the only option?
  • johnbeetem
    Absolutely.  C works great; gcc and make are included in the standard Raspbian distro.  There are a bunch of other choices as well: see the RasPi Wiki at http://elinux.org/RPi_Programming
    Thanks John!!!!!!
    Is there any distribution which has preloaded libraries if I want to test Wireless Communication using Raspberry Pi?
