Raspberry Pi Forum mcp23017 resets and relays stop working!
  • Replies 33 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 6532 views
I have attached AC fan as load to my SainSmart 8 Channel DC 5V Relay Module.
The relay board is supplied with external power supply(5V,1Amp).The relay board is controlled by MCP23017(gpio expander ic connected to my raspberry pi).
The fan is with Regulator.Sometimes when i change speed from regulator the ic is reset and relays stop working.
  • Problemchild
    0 Problemchild over 11 years ago in reply to mcb1
    Yeah you can get away with murder with respect to the correct signal voltages and correct line termination. If that works then great then we wouldn't have this conversation. If it doesn't then it's good to reduce the potential issues by having the correct signal voltages and termination.
    As any one tried driving the Pi and relay boar from a regulated battery source like a battery powered USB charger.. see if stuff is getting through that way ?
    0 mcb1 over 11 years ago in reply to rew
    Rodger
    You quite correct, I had totally missed that the RPi included the pullups.  image
    This just leaves strange earthing and poor regulation which should be resolved with a 0.1/100nF and 100uF capa cross the supply at the IC.
    but stil can there be any spike suppression on the AC main line before relays? and what can be the reason for mov failure?!
