Raspberry Pi Forum raspberry pi to rca tv help
  • Replies 21 replies
  • Subscribers 708 subscribers
  • Views 3581 views
i just got my first raspberry pi B+ and only have a old rca tv and have cant seem to make it work i tested it with a hdmi tv and it works and we loaded raspbian but it still wont work with a rca adaptor any help will be grate thanks?
    is there some ware i can get the file to upload to my SD card i don't now much about righting code and stuff any help will be grate.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    I don't have much experience with NOOBS, but with Raspbian if you put your SD card into your computer you may get a partition called boot. In there may be the config.txt file.
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    thanks
    if i open boot this comes up
    àm‚
    ÀAè@€èC@€1hùÀÏ-À@è@€èûH€1hùÀÏ€¿
      €3€2€1€0€/€.€ åŠ&€Ù€& @@(@€"`@q@‚@€‑`@q@‚@€9
    €2 ||||ZZZZZZZZZ||||A[1]è!à~! l˜[1]è
      !à~`!      [1]è !à~èÿÿÿ?!     [1]è!à~a`!   ! !lþ!  lþ[1]èà~! l•[1]è
      à~`!   [1]è à~èàÿÿ!      [1]èà~Aa!   ! !lþ[1]è à~! l•[1]è  à~`!   [1]è
    i don't under stand
  • gadget.iom
    are you opening up botched.bin?
    if so, this isn't the file I was referring to. There could/should also be a file called config.txt in the same folder.
    i don't see it any ware i have opend all the folders and still cant find it
  • gadget.iom
    Ok. Your installation may not require a config.txt.
    Try the step by step solution on this page: https://bhavyanshu.me/tutorials/force-raspberry-pi-output-to-composite-video-instead-of-hdmi/03/03/2014/
    In step 3 it will ask you to press 1,2,3, or 4. Number 3 is for PAL televisions, and 4 is for NTSC televisions.
    i have it thank yo so much for all your help image
  • gadget.iom
    You're welcome!
    Glad you're all sorted image
    ok so i got it to display the os screen comes up and when i upload raspbian but when it finished the popup came up and sed it was finished i clicked on it and it went back to blue screen any help?
