Raspberry Pi Forum raspberry pi to rca tv help
  • Replies 21 replies
  • Subscribers 708 subscribers
  • Views 3563 views
i just got my first raspberry pi B+ and only have a old rca tv and have cant seem to make it work i tested it with a hdmi tv and it works and we loaded raspbian but it still wont work with a rca adaptor any help will be grate thanks?
  • clem57
    0 clem57 over 11 years ago
    If you have a Windows 7 laptop available, try this Networking 101 and Raspberry Pi 2 Otherwise what connections do you have on the RCA TV?
  • michaelwylie
    0 michaelwylie over 11 years ago
    Check here?
    Raspberry Pi • View topic - B+ RCA Out
    the connectors are the yellow red and white i tested the adapter cord with a multimeter and they are wired correctly
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    Have you read the page suggested by michaelwylie yet?
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    yah i am really new to this and most of it went over my head i just want to use the tv as a monitor
  • gadget.iom
    did you use NOOBS to load Raspbian?
    ok so reading it for the 3rd time i understand i have to set it up with hdmi and change in the settings right?
    yes i loaded it from a factory SD card from makershed
  • gadget.iom
    Yes, you could connect via HDMI and make the necessary configuration changes. Alternatively you could write a default Raspbian image directly to the card, which seems to auto-sense the input.
    ok thanks i will try thathanks for all the help
