Raspberry Pi Forum raspberry pi touch screen issue
  • Subscribers 708 subscribers
  • Views 1550 views
  • raspberry-pi
our touch screen will not boot the image on the sd card,  we've loaded raspiban onto it  but haven't been able to get anything to display on the actual touch screen. we've confirmed that the unit itself is operational and is able to read the sd card, this was done by connecting the pi via hdmi to an external monitor. the screen powers on and greets us with a blank white screen. I'm not certain whether this has to do with the coding on the sd card or if one of our components is damaged or not. we've tried connecting multiple touch screens to other pies as well as ours but the same results follow. does anybody know how to resolve this ? any help is much appreciated
  • rew
    0 rew over 11 years ago
    When you connect the 'pi to an external monitor using an HDMI cable, then you should not just see a blank white screen.
    At first you should see a rainbow square on the screen followed by boot messages from the kernel.
    So: I'm half-convinced that your 'pi is not finding the rigth stuff on the SD card. (faulty devices are rare).
  • clem57
    0 clem57 over 11 years ago
    Please update which model of Pi we are talking about. The New Pi 2 or  ????
    0 e14 Contributor over 11 years ago in reply to clem57
    rapsberry pi model b with full size sd card reader
    0 e14 Contributor over 11 years ago in reply to rew
    the touch screen shows a blank white screen, not the external monitor . sorry for wording my question in a confusing manner
  • mconners
    0 mconners over 11 years ago in reply to e14 Contributor
    You may have to do something like this: http://www.element14.com/community/message/136013/l/re-sainsmart-lcd-tft-pi-32#136013
    It would also help if we knew what touchscreen you were using.
    Mike
    Hi there!
    I too am facing the blank white screen issue with my Pi 2. The connection are all good and I have carefully verified them based on this page. I have run the apt-get update/upgrade step (by first connecting it to an external hdmi monitor). But when I start the pi with the touchscreen, i only get a blank white screen (though the pi seems to be booting up based on the led lights on the board).
    The board was purchased 2 weeks ago, so I would assume its relatively current. Are there any other steps we need to do? There was a mention of installing wheezy instead of using noobs (which is what I set up the pi with), but I would think running the apt-get upgrade would update and install any drivers needed (including enabling the DSI port).
    ANY update on this issue would be most helpful.
    Thanks!
