Raspberry Pi Forum Enable the IT9135 (WandTv) DVB Usb stick
  • Replies 29 replies
  • Subscribers 686 subscribers
  • Views 4900 views
Dear friends,
I tried to ask in many forums (without any success) regarding the use of the WandTv DVB stick on Raspberry PI 2 with any XBMC (Kodi) flavor.
Does anyone knows how to do that in a simple way?
I'm a newbie without much knowledge on Linux, neither programming.
Thank you very much!
Ilan.
    0 Former Member over 10 years ago in reply to rew
    Dear Roger,
    The problem is that the device won't power up...
    I have NOOBS but the device cannot show anything.
    Do you have any advice?
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    The problem is that this is a bit complicated to me to compile drivers in Ubuntu (or maybe Raspian).
    I'm sure that many users do use some kind of DVB stick with any kind of Kodi with Raspberry.
    Isn't a simple solution for that, with simple steps for Raspberry?
    ilan5555,
         I am sorry for your troubles. First I realize you did not account for the new Raspberry Pi 2 and the old Raspberry Pi... Therefore the statement above is true for the OLD Pi and false for the NEW Pi. Please look at first comment in
    http://www.element14.com/community/community/raspberry-pi/raspberrypi2/blog/2015/03/19/see-my-new-pi-2-next-what-should-we-do for a good download of for KODI. Since I know you have driver issues, I will try to build the driver on my Pi 2 after I free it from my current project. That may occur this weekend. I can build it, but not test it since I do not have your device. Let me know when the PI 2 is back to square one.
    Hang in there,
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Dear Clem,
    Now my Raspberry simple won't boot.
    I cannot see nothing from the HDMI.
    Do you have any idea how to make it boot or did I killed my unit?
    Thank you,
    Ilan.
  • clem57
    The hardware is fine. The software is the problem. Take a deep breathe!image What I would like you do is reload the software part. If you have a new card handy, best to use that. If not, the partitions need to be wiped clean. Let me know if you want to reuse the old card and I will have instructions to clean it.
    Clem
    Dear Clem,
    I have 2 micro sd.
    One with OSMC and the other with NOOBS and OpenELEC.
    I tried to boot from both but the HDMI show nothing.
    I have no problem doing whatever you tell me to do.
    0 Former Member over 10 years ago in reply to Former Member
    Well,
    I reinstalled NOOBS to the SD card and the unit works!!
    Now, back to the old question, is it possible to use the card with any kodi variation for Raspberry?
  • clem57
    1. Please take the one with NOOBS, I am going to show you a better version http://www.berryterminal.com/doku.php/berryboot. Take your time and read it,. I believe you will find it easier to use.
    2. If your on a Windows machine launch cmd (aka command line). You will need to launch as administrator if Windows 7 or later.
    3. Enter: diskpart
    4. list disk (enter)
    5. select disk (type the disk number for the SD card not HD. Please double check) (enter)
    6. clean (enter that will delete all the partitions that you have on your card)
    7. then to create a new partition type for FAT
      create partition primary and hit enter
    8. Exit and do a format as FAT.
    9. Download link Berryboot for the quad-core Raspberry Pi 2:berryboot-20150401-pi2-only.zip
      sha1sum: bc7223fde1c54f7047a74534d11dca6900bec60d
    10. Unzip contents to FAT directory
    11. reboot Pi with this SD card.
    12. Look for openelec and wait for it to download. You may need to reconfigure for wireless/wired access.
    13. Here is a picture:
    Berryboot screenshot
    Clem
    Dear Clem,
    What's the difference between this and NOOBS?
    On both we have OpenElec, no?
  • clem57
    This is better for many reasons not the least being better support and open source. I have tried all the choices and found little trouble.
    Clem
    PS I will be around for a while longer should you run into any questions.
    Dear Clem,
    I will try and do that.
    My questions is if this OpenElec will have an option to use the DVB-T stick?
    I can use OpenElec or OSMC or Xbian, all the same to play some videos and music.
    My issue is that I need to configure it for live tv.
