Raspberry Pi Forum Raspberry Pi 2 model B 1 GB hdmi sound problem
  • Replies 15 replies
  • Answers 2 answers
  • Subscribers 708 subscribers
  • Views 4576 views
  • raspberry_pi_space
Got two of them and same problem on both with several hdmi tv(s). Older Pi worked fine on both tv(s). Headphone jack works fine. Used Python Games to switch as well as sudo raspi-com-fig.
  • fredt
    0 fredt over 11 years ago in reply to e14 Contributor
    OK
    I finally got it to work on the small HDTV.
    --I tried the below steps again and it worked finally.
    ---------But Why did the big tv work but not the small tv?
    R-Pi configuration file - eLinux.org
    How to edit from the Raspberry Pi
    This method is most useful if you can see the display of the Raspberry Pi and you wish to make minor adjustments.
    • Reboot the Raspberry Pi and enter your username and password.
    • To edit the configuration file, enter the command
    sudo nano /boot/config.txt
    • Type in the necessary configuration parameters
    • setting hdmi_drive=2
    • Uncomment out
    • Save the edited file
    Press Control-x Press y Press [enter]
    • After exiting the editor, restart using the command
    sudo reboot
    Here is the config file I edited.
    # Uncomment to force an HDMI mode rather than DVI. This can make audio work in
    # DMT (computer monitor) modes.
    #hdmi_drive=2
    Before saving, I went to the blank line below hdmi_drive=2
    This may be the key
    Do not save on the edited line
    I hope this helps for you.
    also see
    R-Pi Troubleshooting - eLinux.org
  • clem57
    0 clem57 over 11 years ago in reply to fredt
    Is the larger TV HDMI 1.4 while the smaller is HDMI 1.3? That would explain a lot.
    Clem
  • clem57
    0 clem57 over 11 years ago in reply to clem57
    fredt
    You may want to try this with the larger tv: https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
    They explain mode support changes that may account for the problem.
    Clem
  • fredt
    0 fredt over 11 years ago in reply to clem57
    Thank you
  • clem57
    Your welcome. Please consider writing or blogging about your new Pi 2 for others to enjoy.
    Have a great day,
    Clem
