Raspberry Pi Forum Audio recording using element14 Cirus Logic (Raspberry pi) and pyaudio
  • Subscribers 692 subscribers
  • Views 295 views
  • python
  • audio
  • program
  • recording
  • raspberrypi
Hi all,
First of all I should say that I'm quite new to Rasberry Pi and Python. I'm trying to write a Python script which will record audio using the element14 cirus logic board and pyaudio and then apply some signal processing algorithms. What I can't seem to understand is how to specify the Input for my data stream...Here's the code I'm using (for the moment I just want to write the data in a a test file)
import pyaudio
CHUNK = 1024
FORMAT = pyaudio.paFloat32
CHANNELS = 1
RATE = 44100
RECORD_SECONDS = 5
OUTPUT_FILENAME = 'test'
p = pyaudio.PyAudio()
stream = p.open(format=FORMAT,
  channels=CHANNELS,
  rate=RATE,
  input=True,
  frames_per_buffer=CHUNK
  input_device_index = 2)
print("* recording")
frames = []
f = open(OUTPUT_FILENAME,'wb')
runflag = 2
while runflag>0
  data = stream.read(CHUNK)
  f.wite(data)
  time.sleep(.001)
  runflag = runflag-1
print("* done recording")
stream.stop_stream()
stream.close()
p.terminate()
I tried different input_device_index when I open the stream but crashes all the time. However if I use input_device_index=2 it just blocks at  stream.read(CHUNK) which I suppose happens because it doesn't get any input data.
Any help would be much appreciated!
