Raspberry Pi Forum Raspberry Pi 2 A/V output via RCA Question.
  • Replies 24 replies
  • Answers 3 answers
  • Subscribers 708 subscribers
  • Views 14170 views
I have the RP2 running RetroPie and have used it via HDMI.
I now want to use my 3.5mm to RCA cable. I have tried but get not picture. My TV seems to see something is there but I get no audio or video. I have made sure the yellow is in yellow, red to red, white to white and that the 3.5mm is firmly in the RP2.
The 3.5 mm jack has 3 black bands if that helps.
Any ideas?
Thanks.
    0 e14 Contributor over 11 years ago in reply to clem57
    Thanks for responding. If I understand correct your asking if I plugged the R, Y, & W plugs to the corresponding R, Y, & W jacks? I did, R to R, Y to Y & W to W in AV1 on my CRT TV.
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Looking at picture #2 must be GND and the yellow can be either video or red is video. So try both. The audio is what left over as over.
    Clem
    I have tried all 3. The yellow is what shows the jumbled mess. I can barely make out the RetroPie boot screen. The others don't have any effect on the screen (completely black).
  • clem57
    Yellow is video and need to adjust resolution for the type of tv. Do you know the make and model?
    Its a Sanyo and I also tried on my son's no name CRT TV with the same result. Anything else I use on those TVs works fine. What kind of settings would need to be adjusted?
    Thanks.
    0 e14 Contributor over 10 years ago in reply to clem57
    hello I m new user like you guys to lovely "Raspberry pi 2" ,
    i m like you faced the problem in getting output on tv using RCA VIDEO cable,but after some research found a complete solution,
    Solution to RCA VIDEO output prolem: Two steps
    Step 1:Hardware setup,i,e whatever the rca cable you have bought mostly have the yellow pin with connections in reverse as per Rapberry pi requirement ,
           so you the cut yellow wire at distance of 10 cm from male pin and reverse the connection with black to yellow and yellow to black, now you are fit with RCA hardware                         compatability.
    Step 2: If you connect Raspy to  tv powered on and then power on your raspy,if you dont see anything on tv (with AV screen on ,for which the Raspy has been connected)
              go for "config.txt" editing ,Add the folliwing lines of code, (note:if a line of code already exist dont repeat it)
    sdtv_mode=2
    hdmi_ignore_hotplug=1
    #hdmi_force_hotplug=1
    #note above lines added to have composite display,and hdmi will not come,if you want hdmi display on,comment above two lines,and uncomment third line.
    i think i have given a quick solution for the problem of not having output on CRT TV using RCA Video cable .
    If your problem is solved please comment out,or for any queries.
    hii kevin .... can u got the result on crt television.... please give me a reply.....
    sir, i m also working on raspberry pi B+ model an connected to crt tv bt i can't got the results.....
    please sir help me.....
    sir, it is possible that we are using HDMI TO RCA cable on raspberry pi and possible it?
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    The HDMI to RCA will not work. For a Raspberry Pi B+ v1 you should try https://blog.adafruit.com/2016/02/05/new-product-av-and-rca-composite-video-audio-cable-for-raspberry-pi/
    Clem
