Raspberry Pi Forum New Pico W
  • Replies 40 replies
  • Subscribers 699 subscribers
  • Views 10617 views
New Pico W
mp2100
mp2100 over 4 years ago
I guess I should have guessed what all that empty space on the original Raspberry Pi Pico board was for.  They put a WiFi 802.11N chip there. CYW43439 from Infineon. This will be a nice board for IoT.  And it's cheap.  $6.
https://www.raspberrypi.com/news/raspberry-pi-pico-w-your-6-iot-platform/
    shabaz over 4 years ago in reply to shabaz
    (Can't edit)
    Another nicer implementation would have been to extend the Pico by an inch, and had the WLAN bits on there, and made it snap-off-able, so you could position it in the best place for your design.
    No-one in a lot of orgs seem to care about good quality wireless in their designs, if they did, then this options would have perhaps been a better choice. You could then even rotate the radiation pattern if required for your project, by (say) soldering on the snapped-off piece vertically using right-angle pin headers, instead of soldering flat on the board. It would become the Pico W user's choice.
  • cstanton
    cstanton over 4 years ago in reply to shabaz
    I see it as the difference between a dev' board for 'testing' functionality of the chip, versus a board ready for embedded production.
    Since you can buy the rp2040 as a standalone chip, perhaps the decision was made to cut costs and options rather than give flexibility because someone can always make their own board? (which different companies have done) - though it could simply be that they (Pi Foundation) didn't think about it or that it wasn't requested.
    Though you'd think it'd be considered since the Pi Zero had the ability to solder a u.fl socket onto the board.
    shabaz over 4 years ago in reply to cstanton
    I think all evidence points to org culture issues with them, they ship "good enough" products but no better. There are so many things they could have done at zero cost, to improve the user experience, but they don't. For instance the upside-down numbering on the Pico, makes no sense. The inability for them place a decent legend on the Raspberry Pi to help people identify pins on the 40-way pin header. Failure to test USB-C power with Apple chargers when they released the Pi 4. The RP2040 chip has an unfriendly 0.4mm pitch (it's a lot harder to use than 0.5 mm pitch, despite the difference being just 0.1 mm). And lack of an option with U.FL as you say.
  • scottiebabe
    scottiebabe over 4 years ago in reply to shabaz
    It's a fair point, though I wouldn't be too worried about it. It does get complicated for users who like to mount the pico with the castellated pads. I'm sure most designs have a ground fill under the antenna. I assume when mounted with 100 thou headers it works well enough.
    shabaz over 4 years ago in reply to scottiebabe
    I think they should have read Dr. Dolittle books, it sums up the problem nicely. I don't know of any product that sticks their antenna buried inside, when it should be facing the exterior of the product, e.g. on an edge.
  • cstanton
    That may be a bit unfair - though I understand having high expectancies of quality standards. From the interviews and how the designers talk about the products, they're simply operating within their means and maybe learning as they go along for the most part.
    They did drop the ball on following the reference design, they quietly fixed that on subsequent Pi 4 releases but didn't announce the revision. I disagree with the practice of not admitting fault and not admitting design differences and improvements. Especially where it matters.
  • scottiebabe
    LOL I love that image. Are there any products using the Pico, aside from devboards for makers?
  • scottiebabe
    You can also find lots of interesting tidbits in fcc report: https://fcc.report/FCC-ID/2ABCB-PICOW/
    Like what's inside the shield can (or just look at the schematic lol):
    I think it's unlikely so far, but perhaps that could change with the Pico W, since it might save costs if wireless certification is not needed in some countries (no idea if that's the case or not, I don't know the legislation in that area). The security (at least credentials, if not firmware) is also something I'm curious about.
    You could be right, although on the flip side, some (me) would argue they have plenty of resources nowadays for top-quality designs with significant testing if they wish. Hard to know.
    Totally agree with what you mention about the design faults etc. They especially rubbed everyone off the wrong way when they banned the first person to identify a hardware bug on Pi #1 from their forum, and ever since have been opaque.
