Raspberry Pi Forum Pi Pico Eurocard - SD Card signals
  • Replies 17 replies
  • Subscribers 701 subscribers
  • Views 4589 views
  • pico
  • pico_eurocard
  • fatfs
Jan Cumps
Jan Cumps over 3 years ago
follow up of an earlier discussion: what do the SD Card signals look like on an oscilloscope.
I've made these connections with the oscilloscope:
EuroCard Pico pin function channel
*CS IO13 SPI1 CSn 4 dark blue
MOSI IO11 SPI1 TX 2 light blue
SCLK IO10 SPI1 SCK 1 yellow
MISO IO12 SPI1 RX 3 magenta
All channels are set to 2 V/div. Here are the results of the start of a communication.:
All 3 scope captures are based on a single sample. Just different locations and time-base views.
This is the old sloppy sample that Michael refers to in the 1st comment:
    michaelkellett over 3 years ago
    These waveforms look a bit odd - is that noise on the MOSI line ?
    Is the 11 clock pulses folowed by clock staying high an SD card thing - ?
    Jan Cumps over 3 years ago in reply to michaelkellett
    that was all my extreme sloppy sampling. I just turned on the scope, put all to 2V, and settled for the first image I could replicate. Channel 2 and 3 were on AC
    I've made new samples - 3 this time. With deep memory on so that I had meaningful info.
    michaelkellett over 3 years ago in reply to Jan Cumps
    Looks much better now - I can believe that might work !
    You get the opposite problem when you use a logic analyser, since the input is just a comparator all the pulses look perfect, and sometimes they really are like your first scope plot.
  • scottiebabe
    scottiebabe over 3 years ago
    Very neat! Great work. I want to experiment with some of these fancy new Pseudostatic RAM memory chips that have a QSPI flash interface.
    If I mod wire this in place of the on pcb flash  on a Pico, I should have 8 MB of RAM! Of course I would have to load the code over the swd interface....
    • Vote Up +6 Vote Down
    michaelkellett over 3 years ago in reply to scottiebabe
    Nice chip. did you mean to pick the 1.8V one ?
    (They do 3.3V as well.)
    I have a socket on a board which can take the Microchip 1Mbit serial RAM but this one is a good bit nicer, and cheap and in stock !
  • scottiebabe
    scottiebabe over 3 years ago in reply to michaelkellett
    I don't know why the 3V version didn't show up in my search but as you say it is there too!
    The ESP32-cam stores its image framebuffer on a PSRAM chip. The teensy 4.1 lets you choose your chip if you so desire:
    https://www.pjrc.com/store/psram.html
    Its a technology too good to ignore, I need to learn more of the nitty gritty details...
    shabaz over 3 years ago
    Hi Jan,
    That's great to see what the signals look like. Neat work with the probes in the cramped space : )
    Jan Cumps over 3 years ago in reply to shabaz
    Yes, the MISO looks healthy to me, without a pull-up:
    For perspective, the first frame, and the start of the second frame, when starting the "simple" test of the test program I'm running. The ~CS being low on CH4 indicates the boundaries of a frame.
    A full cycle: check if a file exist. read, recreate, write lines, close
