Raspberry Pi Forum Problem with raspberry pi 3 B GPIO there are not working , BrachioGraph project
  • Replies 32 replies
  • Subscribers 700 subscribers
  • Views 5980 views
  • problem
  • help
  • gpio
  • robotics
  • servo
  • error
samiboutgoulla
samiboutgoulla over 3 years ago
hello everyone, I created a BRACHIOGRAPH with a raspberry pi 3 and a three servo here is the documentation https://www.brachiograph.art/ and also here is the github link of the project https://github.com/evildmp /BrachioGraph.git , I noticed that it draws me every time a half circle, so I tried to test the GPIOs of the raspberry pi with the servos I distinguished that the GPIOs do not work except GPIO 14 it's the only one that works can you help me
    Jan Cumps over 3 years ago in reply to beacon_dave
    That technique is featured in the video Stuck out tongue winking eye. It's a treasure throve of reliable prototyping - with a little flavouring with high frequency sauce
    shabaz over 3 years ago in reply to Jan Cumps
    Very good video.
    Also sometimes tape can be added to the mix, i.e. cut out some parts, and also use tape where it's convenient. Not as rugged though. More pricey too.. conductive adhesive versions of it are crazy expensive now compared to a few years ago (although a reel of the tape could last for years).
    Jan Cumps over 3 years ago in reply to samiboutgoulla
    How are you powering your raspberry pi?
  • samiboutgoulla
    samiboutgoulla over 3 years ago in reply to Jan Cumps
    I'm using the raspberry pi 5v to run 3 motors
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to Jan Cumps
    With cladboard, there is also the technique to cut round isolated pads with a broken drill or special tools.
    Edit: This is also mentioned in the video that Jan Cumps linked earlier, so 'no news'.
    shabaz over 3 years ago in reply to samiboutgoulla
    It's not your fault because that is what the tutorial suggests to do.. but the tutorial is wrong. It's a disaster to do that. Any slight drag in your mechanics, due to friction, will cause the low voltage to occur, even if perhaps you don't see it initially (I have no idea if you do or not).
    You need a separate 5V supply for the servos if you want to do it properly.
  • samiboutgoulla
    samiboutgoulla over 3 years ago in reply to shabaz
    how do I can't do it ,when i plug in a battery the raspberry pi shuts down
  • samiboutgoulla
    Thank you so much ,can I get your phone number?!
    Unfortunately no, this doesn't scale if people have to give 1:1 phone calls.
    (I don't like doing this anyway).
    The conclusion seems to be to prototype the project properly using any of the methods suggested, and then you can examine powering it as suggested (with a separate DC supply - once your Pi is powered successfully too).
