Raspberry Pi Forum Problem with raspberry pi 3 B GPIO there are not working , BrachioGraph project
  • Replies 32 replies
  • Subscribers 700 subscribers
  • Views 5978 views
  • problem
  • help
  • gpio
  • robotics
  • servo
  • error
samiboutgoulla
samiboutgoulla over 3 years ago
hello everyone, I created a BRACHIOGRAPH with a raspberry pi 3 and a three servo here is the documentation https://www.brachiograph.art/ and also here is the github link of the project https://github.com/evildmp /BrachioGraph.git , I noticed that it draws me every time a half circle, so I tried to test the GPIOs of the raspberry pi with the servos I distinguished that the GPIOs do not work except GPIO 14 it's the only one that works can you help me
  • colporteur
    colporteur over 3 years ago in reply to samiboutgoulla
    I can appreciate the process of resolving the problem may seem frustrating. If you continue to embrace technology it doesn't get better but the enjoyment increases also.
    shabaz over 3 years ago
    colporteur has mentioned the reliability concern too. It can't be overstressed how the prototyping needs to change significantly. It's not surprising that things do not work because you have several points of failure on each connection, due to the way you're connecting and chaining things with unreliable items and techniques.
    If you really want to continue with breadboard then at least replace it. The one you have is so worn out on the outside, that the chances that all the connections inside it are fine is probably close to zero percent. We are talking from many years of experience. The one in the photo below is low-cost, but should work well. Any cheaper will likely not be very good.
    The round-moulded jumper wires you're using are extremely bad. These types are much better (but buy from a good place, because the cheapest ones are sometimes cut inside near the metal crimp, but on the outside look fine).
    Replace the breadboard with soldering. Use pin headers (shown highlighted in red. Here is an example). They will connect to your servos and to the jumper wires to the Pi.
    Underside of the board can look like this:
    or like this:
    The photo above is from here:  Circuit Prototyping
    These are all solid reliable connections that are tested with a multimeter if you're unsure.
    Jan Cumps over 3 years ago in reply to shabaz
    (or cladboard - unetched PCB, and an exacto knife. Costs virtually nothing, lasts for years. The cheapest impregnated paper board works more reliable than a breadboard)
    (impregnated paper is also easier on the knife and lungs than fiber boards)
    shabaz over 3 years ago in reply to Jan Cumps
    The paper boards are brilliant for prototyping! Easy to drill too, with the most cheapest of drills, if that is needed (usually doesn't need drilling at all for quick prototyping).
  • colporteur
    colporteur over 3 years ago in reply to Jan Cumps
    I've not heard of these. I will have to take a look.I normally breadboard and then perf board a CAD PCB design. If it works I'm confident the PCB electrically works. The physical part is where I get into problems.
    Jan Cumps over 3 years ago in reply to colporteur
    Action photo:
    shabaz over 3 years ago in reply to colporteur
    There's some info here with a short video:
     Copper Clad Prototyping Tools
    In brief, the rotary tool there wasn't useful for this prototyping method (but is _extremely_ useful for cutting fine traces on ready-made PCBs). The "scorper" tool is very handy, but exacto knife would be as effective too. I still have not perfected a technique with the scorper (I recently purchased a second scorper with a slightly different shape, but I think it is possible to do better).
  • samiboutgoulla
    samiboutgoulla over 3 years ago in reply to shabaz
    thank you shabaz it works but I'm getting WARING LOWER POWER SUPPLY IN raspberrry pi , should I worry
  • beacon_dave
    beacon_dave over 3 years ago in reply to Jan Cumps
    You can modify that slightly by using this approach:
    /challenges-projects/element14-presents/dc-to-daylight/w/documents/27289/dc-to-daylight-02-a-diy-current-source-demonstrating-ohm-s-law?ICID=dctodaylight-episode-list
