Raspberry Pi Forum Power Raspberry PI using Solar Panel
  • Replies 41 replies
  • Subscribers 695 subscribers
  • Views 20855 views
  • solar panel raspberry pi
  • raspberry pi
  • power raspberry pi solar
feiticeir0
feiticeir0 over 3 years ago
Hi all.
Following a project - AllSky - taking photos all night at the sky - I want to place the PI - Raspberry PI 4 B+ 4GB memory using a SSD NVMe 512GB  - where I don't have a power outlet.
I've the following setup:
- Solar Panel -
  • max power: 20W
  • Vmpp: 18.2V
  • Voc: 22.6V
  • Impp: 1.12A
  • short-circuit: 1.18A
That connects to a Waveshare Solar Power Manager (C), that is powered by 3x 18650 batteries - each battery has 3350mAh - NCR18650B.
I've set the setup voltage switch for 12V - the same as the solar panel.
I don't have a problem with the charging. It charges very well, to full charge.
My problem is, it just wont last all night.
Starting to take pictures at 21:30 (9pm), it only lasts to (the last picture taken) 3:44 (3:44am) . Just over 6h.. This can't be right.
My question is - what can I do to make it last longer. Should I buy more powerful batteries - like 5000mAh or more ? Chose other solar charger ?
I have the Raspberry PI Lite version - and I've disabled some unwanted services like - bluetooth, avahi-daemon, triggerhappy, etc.. I even disabled the status LEDS... Slight smile
Any idea would be great.
Thank you
  • beacon_dave
    beacon_dave over 3 years ago in reply to feiticeir0
    Shrink-wrapped pack I think without the battery holder
    Possibly something like this which is 3x 3500mAh shrink-wrapped
    Buy Now
    I don't have that one either, just the single cell 14500 (but use an external battery pouch with it) one and the three-cell 18650 one you have.
  • feiticeir0
    feiticeir0 over 3 years ago in reply to shabaz
    I might have jumped the gun on this one, but, hey, here it is:
    https://www.aliexpress.com/item/32983015969.html?spm=a2g0o.order_list.order_list_main.4.21ef194dQCtjpu
  • beacon_dave
    Judging by this review, you will be lucky to get 1200mAh out of these
    https://www.youtube.com/watch?v=RtKJFffD0Hw
  • beacon_dave
    If you have sourced your 3350mAh batteries from a similar place, then you may want to check them out, as they may be nowhere near their stated capacity either. Especially if your 10000mAh power bank manages to power the Pi 4 all night long, with some room to spare.
    genebren over 3 years ago in reply to feiticeir0
    There have been battery vendors claiming extremely high capacity values.  The truth is there a limit to the amount of energy that can be stored into a battery, given a certain chemistry and size.  For Li-Ion batteries in the 18650 package, the current maximum is 3600 mAh.  Any advertised value in excess of 3600 mAh is a sham.  Many people, including myself have purchased these so call high capacity batteries only to find that they are nothing but junk.  Not only are they less than the advertised values, but they are also well below the 3600 mAh level.  Don't waste your money on junk batteries.  Buy from reliable sources, and be highly suspicious of any values in excess of 3600 mAh in a 18650 cell.
  • feiticeir0
    feiticeir0 over 3 years ago in reply to genebren
    Thank you all. I'l check them when they arrive. If they are not what they claim, I'll filled a complaint.
    Btw, how can i see if the advertised capacity is really what they have? a multimeter ?
    There are battery testers that can verify the capacity of a battery.  I have built battery chargers for Li-Ion batteries for products (professionally) and projects (hobby).  One way to verify the capacity of battery is charge a dead battery to full capacity while monitoring the charge current. By totaling the charge current over time you can calculate the capacity of the battery.  The same thing can be done by taking a fully charged battery and discharging it into a load while measuring the current.  Again by totaling the discharge current over time you can calculate the capacity of the battery.
    Years ago I posted a blog on a robot project (Walky the Biped Robot - Power pack ) where I charged and discharged a 1200 mAh (14500) battery and discovered that in had a capacity of 210 to 290 mAh. This blog has some more details on the testing of the battery.
    Good luck!
    shabaz over 3 years ago in reply to feiticeir0
    Proving it remotely to AliExpress may be hard. They might not accept anything other than evidence from some pro battery test tool. If you can simply cancel the order now, that would be better. Setting it all up and testing them (when you know from fact that they won't support that capacity) is also a waste of your effort surely.
    michaelkellett over 3 years ago in reply to feiticeir0
    When I've tested batteries of this type (Li-Ion 18650) I've used an electronic load programmed for constant power or current, depending on the application.
    I wouldn't connect an 18650 claiming 12Ah to anything, in fact I wouldn't knowingly allow it into my lab !
    I've had good results from low cost batteries making reasonable claims and very poor results when I have tested ones making extreme claims.
    The big problem with the duff ones is that catching fire is a common failure mode. If you are determined to test them then set up a rig outside with reasonable precautions against it catching fire.
  • feiticeir0
    feiticeir0 over 3 years ago in reply to feiticeir0
    Thank you all for the replies.
    Powering a RPi with solar is really really hard. Slight smile  But lets not discourage.
    What about a 12v battery with a solar controller ?
    Like something like this:
    with something like this ?
    I still have to try the Raspberry PI Zero W 2 .
