Raspberry Pi Forum Raspberry Pi 5 GPIO - Is it the same?
  • Subscribers 701 subscribers
  • Views 7967 views
  • raspberry pi 5 gpio
  • pi5 gpio
cstanton
cstanton over 2 years ago
It's kinda the same, but different.
I'm still waiting to get a hold of a Raspberry Pi 5 myself, we have one shared internally at the moment and that's being passed around to be able to confirm some details!
I've put up a first draft of the Pi 5 Pinout graphic:  Raspberry Pi 5 Pinouts including GPIO for the 40 Pin Header
I'm expecting some changes/improvements to the diagram - but not a great deal! Mainly some of the naming, as the RP1 ( RP1 Datasheet - Peripheral Controller Datasheet Draft ) chip now handles the pinmuxing and GPIO, and has GPIO of its own.
I believe the RP1 dedicates 0-27 of its GPIO to the 40-pin block on the Pi 5 to be used, changed, etc.
There are also new headers on the board, for composite video to the fan and real-time clock battery.
Fortunately, it looks like the majority of your HATs will still be pin compatible!
    shabaz over 2 years ago
    Register addresses may be changed : (
    I had this problem with Pi code transitioning from Pi 3 to Pi 4. Some apps use low-level interfaces, and broke in that transition.
    For a LoRaWAN plug-on module, it claimed Pi 3 and Pi 4 compatibility but actually only worked on Pi 3 (which wasn't an issue since the throughput is so low, the Pi 3 was more than adequate).
