Raspberry Pi Forum How good is WiFi in Raspberry Pi 5?
  • Replies 9 replies
  • Subscribers 698 subscribers
  • Views 28239 views
  • wifi
  • raspberry pi 5
  • raspberry pi 4
  • sma
maxpowerr
maxpowerr over 2 years ago
The new Raspberry Pi 5 again lacks an SMA connector for the WiFi antenna. In Raspberry Pi 4, when using an aluminum case with cooling, the signal dropped significantly.
Again you will probably have to scratch the board.
  • cstanton
    cstanton over 2 years ago
    I also wish there was an SMA connector on the Raspberry Pi 5, unfortunately, there is not.
    This image:
    Is again how it is on the Pi 5, with no easy location to solder the SMA connector to, the jumper resistor is 'broken out' to what looks like a test pad and that is about it.
  • wolfgangfriedrich
    wolfgangfriedrich over 2 years ago in reply to cstanton
    Yes, that seems still the way to do it.
    And on the RPi4 it was not only done by a random Youtuber, but also right here in the community.
    (+) Molex Antenna Adventures starring a RPi4 - element14 Community
    • Vote Up +5 Vote Down
  • cstanton
    cstanton over 2 years ago in reply to wolfgangfriedrich
    An underrated blog post Slight smile Deserving of re-posting in the blogs area of the Raspberry Pi group as "how to mod an antenna onto the Raspberry Pi 4 and 5"
  • misaz
    misaz over 2 years ago
    I think the Wi-Fi is the weakest part of RPI 5. Wi-Fi did huge step forward in last years (ax, 6 Ghz, low power, embedded features, ...), but RPI is still vendor locked on Broadcom module which is not very performant and it is also limited by SDIO interface.
  • scottiebabe
    scottiebabe over 2 years ago
    Those pesky regulatory hurdles...
  • wolfgangfriedrich
    wolfgangfriedrich over 2 years ago in reply to scottiebabe
    So true.
    If they used identical components and layout, they might even have skipped the WIFI/BT active radiated emissions testing and claimed compliance through the testing of the Rpi4 model.
  • scottiebabe
    scottiebabe over 2 years ago in reply to wolfgangfriedrich
    If they included a populated sma connector, they may have to include an antenna as well and demonstrate the end user wouldn't use a different antenna.
  • kmikemoo
    kmikemoo over 2 years ago in reply to wolfgangfriedrich
    Thanks for the reminder.  The mod will be a whole lot easier to find here on e14.
  • maxpowerr
    maxpowerr over 2 years ago in reply to wolfgangfriedrich
    Good article, for some reason I didn’t come across it on E14 before.
