Raspberry Pi Forum How does one set the RTC on the Pi 5 and also recover the time from it?
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 698 subscribers
  • Views 12004 views
andylhart
andylhart over 2 years ago
All is in the subject line. I Have a Pi 5 but have been unable to find out how to use the RTC, there is a a dearth of information it seems.
    0 shabaz over 2 years ago
    There's no RTC in the conventional sense. Linux will maintain its own clock, by obtaining the current time from the network. The time will need to be obtained this way each time the Pi is powered on.
    If you want a RTC that retains its time (for instance through battery back-up with a coin cell etc) and does not require the Pi to be connect to a network time server, then you'd need additional hardware plugged onto the Pi. If you mention your actual end use-case, then it may be possible to provide a better answer to meet your needs.
    • Vote Up -1 Vote Down
  • scottiebabe
    0 scottiebabe over 2 years ago
    Not sure, but it definitely has an rtc community.element14.com/.../how-can-i-connect-a-battery-for-the-real-time-clock-rtc-on-the-raspberry-pi-5 hopefully it just works.
    0 shabaz over 2 years ago in reply to scottiebabe
    What's with the negative vote? That's pretty rude considering it was a genuine mistake when trying to provide a helpful answer.
  • colporteur
    0 colporteur over 2 years ago in reply to shabaz
    RTC DS3221 I have used with some success.
    0 shabaz over 2 years ago in reply to colporteur
    Or it seems just a battery on the Pi 5 (apparently that's new for the Pi 5).
     andylhart I'm presuming you can just use the Linux 'date' command, provided that the correct driver is already part of the new Pi OS. Not many people probably have the Pi 5 yet (I don't), so if there's no other information, I'd try the 'date' command (type 'man date' to see how to use it, or temporarily connect to a network for the time to automatically update).
  • colporteur
    0 colporteur over 2 years ago in reply to scottiebabe
    I found this link and your cable was attached.
    picockpit.com/.../
  • scottiebabe
    0 scottiebabe over 2 years ago in reply to colporteur
    Thanks to the wonderful faq by cstanton  .If we should never use the down vote button, perhaps we should remove it and have likes only?
    Clearly there is an issue here. Negative-vote me whenever you wish. I'm not suggesting that you should never downvote.
    I've called you out on it because I don't think it is justified. You called me out on my comment with the down-vote. What's the difference? I would also stick up for any user if I thought they were getting unfairly down-voted by anyone. Do what you like.
  • cstanton
    0 cstanton over 2 years ago in reply to shabaz
    The Raspberry Pi 5 now has an RTC!
    It's part of the Renesas / Dialog DA9091 PMIC.
    It's supported by a 3v coin cell battery that connects to J5. This means we can now use "hwclock".
    • Vote Up +5 Vote Down
  • cstanton
    With the way Verint operates, upvoted comments become more visible towards the 'top' of the thread, and downvoted comments are less prevalent.
    I can see that being justified with regard to accuracy for someone with a question and looking for an answer.
    It's similar to how Reddit operates. However, functionality on the site is always being assessed.
