Raspberry Pi Forum i2cdetect gives an empty grid
  • Replies 17 replies
  • Subscribers 700 subscribers
  • Views 3591 views
  • raspberry
  • maxim integrated
bugtech
bugtech over 1 year ago
Hi!
I am using SerDes MAX96717F Ser and MAX96714F Des (MAXIM INTEGRATED) along with raspberry pi 4. I want to display the image on raspberry pi using MIPI camera connected to Serializer.
While following some tutorial, I get stuck where i have to check either the i2c detects the devices or not. So i get an empty grid. What can be the issue here??
I am new to SerDes.
Thank you.
  • aswinvenu
    +1 aswinvenu over 1 year ago in reply to aswinvenu
    either you can wire up the I2C using MAX96717F board or from GMSL EVKIT RPI ADAPTER.
    In GMSL EVKIT RPI ADAPTER P17 can be used for the same.
  • aswinvenu
    Try this
  • bugtech
    0 bugtech over 1 year ago in reply to aswinvenu
    IT WORKS!!!
    Now i see the address. Thank you so much for your help!
  • aswinvenu
    0 aswinvenu over 1 year ago in reply to bugtech
    Pleasure helping you :)
  • bugtech
    Sorry. But one more thing. For accessing the RP v2 camera, do i have to also connect SDA, SCL of deserializer? Thanks again
  • aswinvenu
    +1 aswinvenu over 1 year ago in reply to bugtech
    For configuration purpose, Yes! But you can connect them to the same I2C pins of RPi.  You can access it from J4 of MAX96714F BAK.
  • bugtech
    Thanks a lot!!
