Raspberry Pi Forum i2cdetect gives an empty grid
  • Replies 17 replies
  • Subscribers 699 subscribers
  • Views 3670 views
  • raspberry
  • maxim integrated
bugtech
bugtech over 2 years ago
Hi!
I am using SerDes MAX96717F Ser and MAX96714F Des (MAXIM INTEGRATED) along with raspberry pi 4. I want to display the image on raspberry pi using MIPI camera connected to Serializer.
While following some tutorial, I get stuck where i have to check either the i2c detects the devices or not. So i get an empty grid. What can be the issue here??
I am new to SerDes.
Thank you.
  • aswinvenu
    0 aswinvenu over 2 years ago
    Did you enable the i2c interface in RPi 4?
    sudo raspi-config
    go to Interface options -> I2C
    Once you wire up the SDA (pin 3), SCL (pin 5). You can run i2cdetect tool to check the device is available.
    (Pin-out reference : https://www.raspberrypi.com/documentation/computers/images/GPIO-Pinout-Diagram-2.png?hash=df7d7847c57a1ca6d5b2617695de6d46)
    i2cdetect -y 1
    If you don't see the address of the I2C slave device ( in your case MAX96717F ) Then you check any thing is wrong from the MAX96717F board side.
    Aswin
  • aswinvenu
    0 aswinvenu over 2 years ago in reply to aswinvenu
    According to the datasheet
    https://www.analog.com/media/en/technical-documentation/data-sheets/max96717f.pdf
    Voltage at the CFG0 pin decides the interface I2C/UART
    Please make sure that your board has these pin voltage set as per the table.
  • bugtech
    0 bugtech over 2 years ago in reply to aswinvenu
    Hi aswinvenu
    Thank you for your response.
    1: I have made sure to install i2c tools and enable it on RP4.
    2: I am not sure how to wire up the SDA and SCL pin. Do i have to place a jumper on pin 3 and 5? Or do i have to place a jumper on 3:4, 5:6.
    Kindly guide.
    Thanks again!
  • aswinvenu
    0 aswinvenu over 2 years ago in reply to bugtech
    Can you please share the EVAL Board pic? Are you using MAX96717F-AAK-EVK ?
  • bugtech
    RP4MAX96714F BAKMAX96717F AAK
  • bugtech
    0 bugtech over 2 years ago in reply to bugtech
    These are the boards i am using. MAX96717F AAK (Serializer) MAX96714F BAK (Deserializer) RP4 to display the output of the RP camera V2 connected to serializer.
  • aswinvenu
    I can't see the connection between RPi and MAX96717. I assume you are connecting them using some jumper cables.
    Note : The voltage divider required for configuring the voltage across pin CFG0 is controlled via a digital potentiometer IC (MAX5419)
    If this was not properly set you wont get the I2C access. You can either download the eval solftware and configure the voltage there
    or
    Remove 0E resister R150 and place it at R20. This will enable the on-board potential divider( R15, R79) to control the CFG0 voltage.
  • bugtech
    I am using GMSL EVKIT RPI ADAPTER to make the connection between SerDes and RP4.. (https://wiki.analog.com/resources/eval/user-guides/ad-gmslcamrpi-adp)
    Also i have assembled 0 ohm on R66, R70 and R80.
  • aswinvenu
    These are for connecting to RPI's CSI port. It has nothing to do with the I2C. Can you please show how you are wiring the I2C?
  • bugtech
    Thats what i am unable to understand. How to wire I2C. I thought it made the communication with the 15way cable already. Can you please guide how to wire I2C? Sorry but i am super new to serializer.
