Raspberry Pi Forum I am having trouble with my Pi-Desktop computer kit SATA bridge
  • Locked Locked
  • Subscribers 698 subscribers
  • Views 1369 views
  • ssd
  • sata-to-usb
  • pi desktop
  • raspeberry_pi_accessories
LesRhorer
LesRhorer over 1 year ago
I have a Pi-Desktop case with the SATA bridge, and it no longer sees the /dev/sda target.  I am unsure if it is a bad SSD or a bad bridge.  I don't have another mSATA slot to check it.  I have poked around, but I can't find a likely piece of hardware that would seem to be the bridge.  I have tried lsusb, lshw, etc.  Is there away I can inspect the bridge to see if it is operating?
  • vmate
    0 vmate over 1 year ago
    Do sudo dmesg and see if any related errors are shown. Also try comparing its output with the SATA bridge connected and disconnected.
  • LesRhorer
    0 LesRhorer over 1 year ago in reply to vmate
    No errors from dmesg.  I did try with and without the bridge, but I didn't spot any differences.  That does not necessarily mean there are none.  I did realize it might be because the pidesktop-base deb file is not installed.  It's giving me some errors apparently because it was written in Python 2, which is deprecated.  I am tryingto fix the errors, but one of them has me puzzled.
  • cstanton
    0 cstanton over 1 year ago in reply to LesRhorer
    It is rather old, unfortunately
    https://github.com/pi-desktop/
  • LesRhorer
    0 LesRhorer over 1 year ago in reply to cstanton
    Yeah.  It doesn't like line.count(key) when key is a str.  I don't know why.I am not sure if I should cast it to a byte, or what.
  • cnobile
    0 cnobile 7 months ago
    If you have an eSSD on the card, remove the jumper and plug the USB connector from the bridge into your computer. It should pop up as a removable drive that you can read and write to. If it doesn't, the bridge may be bad. Of course you'll also need to plug in a power adapter.
  • rip
    0 rip 7 months ago in reply to cnobile
    Will try again
    Thanks for your help
