Raspberry Pi Forum Raspberry with vertical TV - how to rotate
  • Subscribers 700 subscribers
  • Views 585 views
ramzam82
ramzam82 4 months ago
Hi all we just connected a Raspberry Pi to a TV which is turned on its side, in a vertical/portrait orientation.
Can anyone advise how we can do it as quickly as possible please?
Its connected via HDMI
  • cstanton
    0 cstanton 4 months ago
    Hey ramzam82 ,
    Are you running Raspberry Pi OS on the Raspberry Pi?
  • kmikemoo
    0 kmikemoo 4 months ago
    EDIT 2026-05-07:  colporteur is right.  It depends on the version of the Pi.  This is why cstanton asked.  I only tried it on my Pi3.
    Welcome to playing with the Raspberry Pi.  This worked on my Pi3.
    Open a Terminal Window.  That's the black square in the upper left -ish area of your screen.  For you... you may have to lean left or right for a bit for decent orientation, but this is a quick fix.
    In the terminal window...
    sudo nano /boot/config.txt
    Add display_rotate=1  to the bottom of the file
    Press Ctrl+X, Press Y, Press Enter
    sudo reboot
    Good luck.
  • battlecoder
    0 battlecoder 4 months ago in reply to kmikemoo
    +1 to this. I'm pretty sure this is how I did it for a project that required a rotated screen. Just to add to this, =1 is a 90 degree rotation, =2 would be 180, and =3 would be 270.
  • colporteur
    0 colporteur 4 months ago
    The fix may worked based on context. When I had to do this, it was depended on Raspberry Pi OS version. I also recall hardware version had something to do with it being successful.
    I have no Pi's to try it but figured I'd add my context input.
  • kmikemoo
    0 kmikemoo 4 months ago in reply to colporteur
     colporteur You are right.  I tried it on my Pi400 and nothing happened on reboot.  Maybe that was why the OP asked the question.  I editted my original response.
  • beacon_dave
    0 beacon_dave 4 months ago in reply to kmikemoo
    display_rotate looks deprecated:
    https://www.raspberrypi.com/documentation/computers/legacy_config_txt.html#display_hdmi_rotate
    https://www.raspberrypi.com/documentation/computers/configuration.html#display-settings
