Artificial Intelligence and Machine Learning
Forum IA Generador neural network library for microcontroller
Join Artificial Intelligence and Machine Learning to participate - click to join for free!
  • Replies 10 replies
  • Subscribers 95 subscribers
  • Views 665 views
rbasulto53
rbasulto53 3 months ago
Hello, please let me know what you think of this AI web application for improvement. It allows you to generate trained neural network models for use with microcontrollers like Raspberry Pi Pico, ESP32, etc. These models don't require an internet connection and are trained by loading a CSV file. It dynamically maps inputs and outputs and has two hidden layers whose architecture can be configured.
The link is:
https://traindeep.ai
thanks
  • BigG
    BigG 9 days ago
    Interesting and I can see this helping others, especially in the teaching world. It would help if you provide a bit of history and what's the background to this project. Based on the contact email, you are involved in education/teaching and robotics.
    Otherwise, a key issue will be to explain what happens to your data. Is it processed locally or is it on the cloud and then what. Where does your data go.
  • hazratbilal
    hazratbilal 13 days ago
    rbasulto53 said:
    thanks
    This is an interesting project, especially with machine learning moving toward smaller devices and microcontrollers. Lightweight neural network libraries seem really useful for processing data locally without depending too much on powerful hardware or cloud services. I’d be interested to see how these models handle limited memory and processing power in real-time applications. I’ve also been exploring practical tech and gaming projects at astutebetaserver
  • rbasulto53
    rbasulto53 3 months ago in reply to Qbit
    hi,
    We ran tests on the rp2040 and obtained these measurements (execution time of already trained model)
    - 3 inputs, 2 hidden layers, and 6 neurons per layer with ReLU activation function: 3.5 ms
    - 3 inputs, 4 hidden layers, and 10 neurons per layer with ReLU and Leaky activation function: 7.1 ms
  • rbasulto53
    Ready version 2.0.
  • rbasulto53
    rbasulto53 3 months ago in reply to DAB
    thanks for you comment.  Please check out the new version 2.0. It has much of what you mentioned and much more.
    DAB 3 months ago
    If you want anyone to bother with your link, you should greatly expand your description of what is at the end of the link.
    It generates a trained NN. So what?
    Give me a useful example so I can be intrigued about the possibilities.
    Provide a walk through of the process so I can see how easy it is to use.
    What is the size of the resulting output? How useful is it? How limited is its application?
    You have to make a reasonable effort to sell it if you want anyone to kick the tires.
  • rbasulto53
    Thank you very much for your comment. Yes, I will be running performance tests, although the generated library is very lightweight for high performance and low resource consumption.
    Another important difference is that it doesn't require installing anything to create the model, as it's trained on the web, and you don't need any libraries to run the trained model; it's very simple.
  • Qbit
    Qbit 3 months ago
    This is a really interesting project! I've been exploring the challenges of running neural networks on microcontrollers myself. Have you had a chance to compare the performance of IA Generador against other lightweight libraries like emlearn or NNoM? I'd be particularly interested in seeing a benchmark for inference speed on a Raspberry Pi Pico or an STM32 board. I'm excited to see where this project goes. Keep up the great work!
  • rbasulto53
    Thanks for the welcome, this application is to help the community and has no commercial purpose.
  • colporteur
    colporteur 3 months ago
    What would be my motivation, to have me click on a link, from a user with a profile of 25 points.
    That score would suggest you are new to the E14 community. Welcome.
