Raspberry Pi Forum Raspberry Pi 5 randomly reboots when powering an SSD over USB
  • Replies 16 replies
  • Subscribers 703 subscribers
  • Views 146 views
  • Locale or Language
italo_ragazzo
italo_ragazzo 19 hours ago
I’m using a Raspberry Pi 5 with an NVMe SSD connected through a USB 3 enclosure. The Pi works normally when the SSD is disconnected, but occasionally reboots when the SSD is under sustained read/write load.I purchased this one in Italy, so it might function differently.
The power supply is rated at 27W, and the issue seems more likely to happen when the CPU is also under load. Has anyone seen this with the Raspberry Pi 5, and would using a higher-rated USB-C supply or a powered USB hub be the recommended solution?
Thank you
best,
Salvatore B.
florist Italy
LTC
  • veluv01
    0 veluv01 4 hours ago in reply to cstanton
  • veluv01
    0 veluv01 4 hours ago in reply to veluv01
    Here's the USB Power Delivery WhitePaper
  • ralphjy
    0 ralphjy 2 hours ago in reply to ralphjy
    I should have added that you need to verify the USB power capability of the ports on the hub and enclosure.  The best solution is probably to use a self-powered enclosure.  Does yours have the ability to plug in an external power supply?
  • Andrew J
    0 Andrew J 2 hours ago in reply to ralphjy
    IIRC the power supply plugs into the enclosure to power everything.  It is a PI5 case rather than a generic one.
  • Andrew J
    0 Andrew J 2 hours ago in reply to veluv01
    When I get home I’ll dig it out.  I formatted it with HAOS but presumably the underlying config is common.
  • colporteur
    0 colporteur 16 minutes ago in reply to cstanton
    I'm not that confident in all PI5 supplies being the same. The 5A sucker is much larger and weightier than the typical Pi power supply. I have a variety of PS kicking around and the size I noticed.
    I'm not saying you are wrong but PS for Pi's has always been contentious issue for me.
