Raspberry Pi Forum Raspberry Pi B+ I2C cannot work
  • Replies 14 replies
  • Subscribers 707 subscribers
  • Views 4787 views
pi-destroyer
pi-destroyer over 10 years ago
My raspberry pi cannot detect device. When I issued command "sudo i2cdetect -y 1", then I will always get:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a UU 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a UU 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b UU UU 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
I am not sure it is a hardware or software issue.
Can anyone help me on this please?
Thanks.
  • pi-destroyer
    More info:
    Even without any devices is connected, the command output is still the same. image
  • clem57
    clem57 over 10 years ago
    Check if I2C is enabled like in this https://learn.sparkfun.com/tutorials/raspberry-pi-spi-and-i2c-tutorial/i2c-0-on-40-pin-pi-boards
    Clem
  • pi-destroyer
    pi-destroyer over 10 years ago in reply to clem57
    Hi Clem, thanks for the reply! image
    Currently I only connecting SDA1 (GPIO2), SCL1 (GPIO3) and GND (Pin 6 in J8) to my device.
    Do I need to enable I2C0 (ID_SC & ID_SD) as well?
    Can you explain more?
  • clem57
    clem57 over 10 years ago in reply to pi-destroyer
    Rasbian may need driver code enabled for any I2C. Follow link above for how to.
  • pi-destroyer
    Add "dtparam=i2c_vc=on" to config.txt and reboot, but the problem is still the same
  • pi-destroyer
  • clem57
    I see the version of linux is older 3.18.11+ from April 21, 2015 which probably is Wheezy. Can you update to Jessie which I am running?
    Clem
  • clem57
    clem57 over 10 years ago in reply to clem57
    Here is mine:
    pi@raspberrypi:~ $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description: Raspbian GNU/Linux 8.0 (jessie)
    Release: 8.0
    Codename: jessie
  • rew
    rew over 10 years ago
    Because i2c-detect runs (it would otherwise complain: /dev/i2c-1 not found), you have I2C enabled. Good.
    i2c detect works by sending an address and then waiting for a "ok goahead" signal from a connected i2c-device. If there is no device, there will be no "ok go ahead" signal, and i2cdetect knows there is nothing there.
    However in your case, i2cdetect thinks there is a device at each address. I think this is most easily explained by the i2c-data signal being LOW all the time. The signal being low normally signals "go ahead" but it is not supposed to stay low, only when a device is being addressed.
    So I would suspect that something is keeping your i2c lines low. First start out by removing all i2c devices that you have already hooked up.
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago
    you do have pull up resistors right......
