Raspberry Pi Forum LCD
  • Replies 28 replies
  • Subscribers 708 subscribers
  • Views 5279 views
LCD
Workshopshed
Workshopshed over 9 years ago
I got myself a 7inch LCD cheap on Ebay thinking that it had a HDMI connector on it but it actually only has a ribbon connector which is described as a "LCD Interface 24-bit parallel".
7" Capacitive Touch 800*480 TFT TTL LCD Screen Display Module For HDMI | eBay
LCD Interface Definition
PIN NO. SYMBOL DESCRIPTION Type FUNCTION
1 VLED- Backlight negative input Backlight negative, connects to GND or PWM control
2 VLED+ Backlight Positive input Backlight Positive, 5V typical
3 GND Ground input Ground
4 VCC Power supply input Power supply, 3.3V
5 R0 Data lines input Red layer data lines
6 R1
7 R2
8 R3
9 R4
10 R5
11 R6
I was wondering if there was some kind of module I could get that would convert the HDMI signal back to the LCD signal. Any suggestions what to search for?
  • the-dubster
    the-dubster over 9 years ago
    Now I've started some digging,  could this be the standard LVDS interface used on Laptop screens (and LCD monitors)?
    If so, they're available fairly cheaply from ebay and such. If it is LVDS then the really cheap ones (£4-5 GBP) sort of work ok-ish, more expensive are better.
    I'm still digging and will report back though.
  • the-dubster
    the-dubster over 9 years ago in reply to the-dubster
    It's looking more likely!
    LCD connectivity - Texas Instruments Wiki
    Extract:
    "Currently there are 2 common color depths in LVDS LCD panels, namely 18 bit and 24 bit. When connecting to 18 bit LCDs there is a defacto-standard for the assignment of the color data bits on the LVDS serial data channels. For 24 bit LCDs there are 2 different common assignments and it is important to know what your particular LCD panel expects. Some 24 bit LCD panels can be configured in either of the 2 formats which can be extremely useful, allowing you to design hardware that can drive either 18 bit or 24 bit LCDs with no hardware or software changes."
  • the-dubster
    Or even possibly . . . . .
    https://www.raspberrypi.org/documentation/hardware/raspberrypi/dpi/README.md
  • the-dubster
    If it does turn out to be LVDS . . .
                   Righto, here is an eBay.co.uk link to a board (and screen - which I know you don't need).
                   Included in the listing is a bunch of compatible displays and - more helpfully maybe - they offer a match-up service to your screen.
                   Could be a starting point.
                   HDMI VGA DVI 50PIN TTL LVDS Controller Board+8inch LCD Display for Raspberry PI | eBay
  • rew
    rew over 9 years ago in reply to the-dubster
    The "less than 5 pounds" boards that you can buy on ebay seem to be boards for a specific monitor or laptop. Not generic HDMI to LVDS conversion boards.
  • the-dubster
    the-dubster over 9 years ago in reply to rew
    They are, but a TV repair friend of mine has used them to 'test' LCD panels in the absence of alternatives - hence the 'sort of work-ish' comment. Whether he purchased a specific type I don't know, the gist of my comment was - buy better ones.
  • the-dubster
    I'm kinda crossing my fingers for the DPI option . . . . image
    P.S.  Multiple posts as 'unexpected errors' were stopping me from editing posts! image
  • rew
    Often essentially the same stuff is sold for less, especially when there is a drive to cheaper stuff, like on Ebay. In that case, "more expensive" doesn't often mean that you're getting better stuff. So I would normally still investigate the cheaper option to see if that would work. This tendency to buy the cheapest variant sometimes gets me burned. I know the risks. In this case I would probably be hesitant to try it because I have more confidence in the more generic variants.
    So, even if your friend managed to get an LCD panel working, it just might be that he happened to have a panel with the same dimensions (in pixels) as the original. Maybe because he knew that this was required, maybe because he was lucky. The story from "a friend" never tells that kind of details. :-)
  • Workshopshed
    Workshopshed over 9 years ago in reply to the-dubster
    I did some counting and the cable has definately got 50 pins. Its too fine pitched but also too wide to fit into the DPI connector.
    The connector that goes from the LCD to the board is labelled as 7dd1+1 fpc and the front of the board LCD070. The resolution is 800 * 480 (Pixel).
    The possible candidate driver I found was this one which uses a VS-TY2662-V1 chip described as coping with 7 to 10 inch boards
    New SainSmart 10.1 Inch TFT LCD Monitor Driver Board HDMI VGA for Raspberry Pi | eBay
  • the-dubster
    I agree with you there Roger, was I said, I have few (read none) real details - all I was driving at was the cheap items can work (panel dependent I agree), but not necessarily how you need / expect.
    If it is LVDS then the eBay link gives at least a small chance that the seller can supply the correct board, and If they screw up then nothing is (hopefully) lost except time - seller refunds if it's their fault.
    TBH I'm going down a similar line here, old XVGA laptop monitor that I'd like to reuse, previous searches (about 7-8 years ago) yielded converters at about £100-200 GBP!! Alternative screens were cheaper!
    Now with the prices between £5 and £50 it's a viable choice - and one I'm willing to take for a fiver.
                   (Note I say I'm willing to take - not I'm advising anyone else takes).
    So yes, both options should be investigated, if possible the panel and driver should be matched too. Hopefully what I have provided is what was requested - some direction with what to search / investigate.  image
